Big oil leak
Old 12-05-2006, 07:22 PM
trike1946's Avatar
trike1946
trike1946 is offline
Question Big oil leak
My 97 has been running very well and not one leak. Today I ran it a lot at the job because I was using the inverter to power a drill. I happened to look at the front of the truck, and there was a puddle of oil under the front. From what I can see it is probably the front main seal.
How big of a job is it? What is the easiest way to go about it. I assume the radiator has to come out.
Thanks for any help.
Old 12-05-2006, 07:31 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
I would bet that its a oil galley plug on the front of one of the heads. They have oring that sealt hem and they go bad sometimes. also could be the front main but thats pretty rare.
Old 12-05-2006, 07:39 PM
trike1946's Avatar
trike1946
Without pulling the air cleaner, I can't see a thing. It ends up dripping off the front of the oil pan. It could be from higher up. I will look in the daylight.
Old 12-05-2006, 07:46 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
oh yeah you got a van. I did a fuel filte on one once. Hope I never have to work on another ever again!
Old 12-06-2006, 02:44 PM
bkcowboss's Avatar
bkcowboss
bkcowboss is offline
check your valve covers they are known for loosening after a while and causing a slow leak, I would check all other possble leaks before delving into rear main seal unless you are sure.
