Closed Knuckle Dana 44
I have a closed knuckle dana 44 front end from a 59 f 250. I need to rebuild the steering knuckles and was wondering if anyone knows where I can get the king pin bearings and the large seal that holds grease in the knuckle. I have checked with the local parts places and they can't find anything.
not sure what you are looking for but here are some sights that may help
http://www.partsmikeparts.com/catalog.htm
http://www.rockstomper.com/catalog/products.html
http://tomsbroncoparts.com/products.php
Thanks for the recommendations. I have checked online and haven't found anything yet so I will have to get ahold of them and see if they have what I am looking for. I did however find a place that has what I need I think. novak-adapt has a steering knuckle repair kit that appears to be what I am looking for. All there stuff is for jeeps. Would a closed knuckle dana 44 found on a jeep be the same as on an f250? At least as far as the king pins and seals.
Kind of an old post, but I have found the bearings and races at Napa (BR11590, or BR23100 depending on HD or STD.) They are listed as steering knuckle bearings, and found them with my truck loaded into the vehicle description. 1968 F250 4x4. The knuckle seals that seal the back side i had to order online from one of the 4x4 parts sites, mostly at the old jeep parts suppliers. Dana Spicer still supplies them. Hope this helps somebody else.
farmer460
26
12-15-2023 12:47 PM
