Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 12-04-2006, 11:52 AM
beekermartin beekermartin is offline
Garage is empty, add now
beekermartin is starting off with a positive reputation.
Code P0174 system too lean bank 2...
I was coasting down a steep hill yesterday when the CEL came on. I pulled the code this morning and got code P0174, system too lean bank 2.
I cleared the code. Should I just wait to see if it happens again? The truck is running great. There is no sign of a problem.
BTW, it's 99 F150 5.4.
  #2 (permalink)
Old 12-04-2006, 12:26 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
1999 Ford F-150
My Garage
BURNSTOUGHFORD is gaining momentum as a positive member of FTE.BURNSTOUGHFORD is gaining momentum as a positive member of FTE.
ya my dads Screw with a 5.4 did that the other day with a small hill and 6000 lbs on a trailer behind it.... we cleared it and it never came back...it was about 2 weeks ago.... anybody know what causes this?
__________________
2012 F-150 SCREW 3.5TT FX4 3.73
2011 Mustang GT Premium Auto 5.0
2010 Taurus SEL
1999 F-150 SCAB 5.4l Lots of Mods
  #3 (permalink)
Old 12-04-2006, 12:34 PM
amerimutt amerimutt is offline
amerimutt is starting off with a positive reputation.
It will come back sooner or later! you have either a vacuum leak (hoses- gaskets) or your MAF needs a cleaning
  #4 (permalink)
Old 12-04-2006, 01:27 PM
Mine came on while I was off the gas and coasting down a hill. The code reader snapshot said it occured at 614 rpms. I think I am going to wait to see if it comes back on again. If it happened while it was under load I would be more concerned.
  #5 (permalink)
Old 12-04-2006, 04:10 PM
that's breif of a read (snap shoot) came up once, you should be good! blip you once blip you twice come back three not so nice
  #6 (permalink)
Old 12-04-2006, 04:11 PM
That's "Brief" for can u spewl
  #7 (permalink)
Old 12-04-2006, 04:15 PM
shanesF150 shanesF150 is offline
shanesF150 is starting off with a positive reputation.
im getting the same code plus p0303 and p0304 .... happen to me pulling my trailer
  #8 (permalink)
Old 12-04-2006, 10:45 PM
Quote:
p0303 and p0304 are misfires on cylinders 3 and 4. Check your plugs and coil packs.
  #9 (permalink)
Old 12-04-2006, 10:49 PM
clifftown2000 clifftown2000 is offline
clifftown2000 is starting off with a positive reputation.
i am getting the code p175 saying running rich bank 2 what should i do
  #10 (permalink)
Old 12-04-2006, 10:52 PM
Your running rich... Better then running lean lol...
Im not to sure... somebody will pop up with something tho
  #11 (permalink)
Old 12-04-2006, 10:55 PM
i have changed plugs had it cleared and it can back and it is the only code.
  #12 (permalink)
Old 12-05-2006, 01:38 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
2002 Ford F-150
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
clifftown2000i am getting the code p175 saying running rich bank 2 what should i do
Clean your Mass Air Flow sensor with brake cleaner or electrical cleaner, something that dries clean with no residue. Let it air dry. DO NOT touch the fine wire in the sensor, it is very delicate and breaks easily. Reset the code after it is cleaned.
__________________
John, aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege, 5.4L 3.55 LS, 4x2, Diablosport Predator Programmer, K&N filter.
FTE Ride of The Week, 4/20/09 !!!
`08 Mercury Sable Premier, 3.5L Duratec, 6 speed auto
  #13 (permalink)
Old 12-05-2006, 04:56 PM
thanks for the info i will try that and see what happens.
  #14 (permalink)
Old 01-04-2007, 06:15 PM
The check engine light came back on! This time it was p0171, bank 1. I reset the code and then started to do some investigating. I started by removing the air intake to clean the mass air flow sensor and throttle body.
After I did that I checked all the vacuum lines. Wouldn't you know it, I found a bad connector! The rubber vacuum elbow on the fuel pressure regulator had a huge hole it it. It looks like something hot touched it or someone tried removing it with pliers and ripped it.
I installed a new one and cleared the code. That should fix the check engine light problem. Only time will tell....
  #15 (permalink)
Old 01-08-2007, 02:08 PM
The code came back on this afternoon. This time it was p0174, "system too lean bank 2". It came on again while I was barely moving at idle. What should I check next?
Tags
2, 2002, bank, clean, code, e150, f150, ford, ii, lean, maf, number, po174, sensor, sistem, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
