Low Speed Miss - Ford Truck Enthusiasts Forums
Low Speed Miss
Old 12-04-2006, 11:50 AM
JDS549 JDS549 is offline
JDS549 is starting off with a positive reputation.
Smile Low Speed Miss
130k MILES, USES A LITTLE OIL, HAS NOT BEEN ABUSED. I have picked up a low speed miss which is worse when cold. Runs good under power. Really bad when I first start. thanks for the help. JDS549
Old 12-04-2006, 03:30 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Sounds like a weak or partially clogged injector to me.
Old 12-04-2006, 03:59 PM
WMRiceman's Avatar
WMRiceman WMRiceman is offline
WMRiceman is gaining momentum as a positive member of FTE.
Would a partially clogged injector cause a code to set? Just wondering.
Old 12-04-2006, 04:20 PM
I am not showing a code...... Jerry
Old 12-04-2006, 04:30 PM
Quote:
It didn't on mine when it was rocking during the fast idle warm up. Stick shift shaking and everything.
Old 12-04-2006, 09:00 PM
Greg99F250SDPS73's Avatar
Greg99F250SDPS73 Greg99F250SDPS73 is offline
Greg99F250SDPS73 is starting off with a positive reputation.
My 99 is doing same thing ... more noticeable after a long haul and you stop at a red light ... feels like im semi bouncing up and down ... stick shaking about 1/4 inch .... not as noticeable while accelerating but seems rougher than what i once thought was normal vibrations .... I tried a bottle of "GUMOUT Diesel Fuel Injector Cleaner" a couple of weeks ago to see if i would notice any difference .... it acuallt seemed to be getting worse.... on top of that i have noticed a small leak on driveway... smells like oil (just noticed it today) this may be from loose oil filter.. just recently had it replaced.
How many times and how often should i run a bottle of diesel kleen through it to make sure i have them kleen .... they have never been cleaned (128K miles)
Old 12-04-2006, 09:54 PM
I run Deisel Kleen on every tank, unless I have some Bio-diesel in it.
2015 F350 Steering jds92570 1999 to 2016 Super Duty 95 02-12-2016 09:15 AM
2015 F350 ride and Tire Pressure jds92570 1999 to 2016 Super Duty 16 09-30-2015 12:07 PM
Engine hesitation under easy acceleration jds872 1997-2006 Expedition & Navigator 12 08-12-2015 01:15 PM
need help 69 f100 FY549 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-07-2014 07:38 PM
Helium in tires? jds1971 1967 - 1972 F-100 & Larger F-Series Trucks 25 10-24-2002 10:48 AM
Tags
1994, 1999, 2000, 40, 54, 73, diesel, f150, ford, low, miss, power, powerstroke, sohc, speed, stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
