Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-04-2006, 10:51 AM
TMI's Avatar
TMI TMI is offline
TMI is starting off with a positive reputation.
Dan Lee 434 on the dyno
Monday 8:00 Am
__________________
Tim
  #2 (permalink)
Old 12-04-2006, 12:47 PM
garypettengill's Avatar
garypettengill garypettengill is offline
garypettengill is gaining momentum as a positive member of FTE.
That appears to be an EFI fuel system. Can't wait to see the numbers.
  #3 (permalink)
Old 12-04-2006, 03:59 PM
TMI's Avatar
TMI TMI is offline
3:00 and all is well. Running, some minor tuning and we will have some numbers shortly.
__________________
Tim
  #4 (permalink)
Old 12-04-2006, 04:05 PM
klatt_89 klatt_89 is offline
klatt_89 is starting off with a positive reputation.
Beautiful looking engine, glad she's running good, let us know the numbers on it.
__________________
1999 F-150 SuperCab Long Bed
  #5 (permalink)
Old 12-04-2006, 04:25 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a very good reputation on FTE. arctic y block has a very good reputation on FTE. arctic y block has a very good reputation on FTE.
I am old school so don't laugh to hard. but what engine did ya start with to get the 434?
__________________
62 UNI Wide Window SWB 390 C6
66 F350 Flat Bed Hi Pro 427 4 speed
7 4X4 Rangers 84 - 89
55 Fairlaine Town sedan 272 Ford O Matic
Show all the luv ya can while ya can. Or one day ya may be alone
Don't just Modify it Fordifiy it
  #6 (permalink)
Old 12-04-2006, 04:49 PM
TMI's Avatar
TMI TMI is offline
Torque 518
HP 481
first pull with 20 ignition, and a crappy dist. (mine)
__________________
Tim
  #7 (permalink)
Old 12-04-2006, 08:25 PM
danlee's Avatar
danlee danlee is offline
danlee has a good reputation on FTE. danlee has a good reputation on FTE.
Quote:
That is a Ford 400 motor. It is bored +0.030" and stroked to 4.25". The heads are CHI-3V alloys. The above dyno plot was with a carb (size ?). The EFI runs will come later.
  #8 (permalink)
Old 12-04-2006, 08:33 PM
I knew the M's Had it in them but never thought any one would do it. especially with all the other options out there. MY hat is of to you. (infact I haven't seen my hat all day) Nice looking Modified hope it dose you well.
__________________
  #9 (permalink)
Old 12-05-2006, 12:32 AM
roger dowty roger dowty is offline
roger dowty is gaining momentum as a positive member of FTE. roger dowty is gaining momentum as a positive member of FTE.
400 isn't an M. 351M is though. yea, look around the forum and search builds- 400 has a history of greatness as of late.
Tim...what distributor are you referring to?
__________________
'77F1504x4, '75 f250crew4x4, '79 Bronco 429, '83 bronco, '72 Torino with 351cj, 70 1/2 falcon, 75 stangII. all projects, 2 on the road. One pissed off wife!
  #10 (permalink)
Old 12-05-2006, 12:36 AM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE. mustange70 has a good reputation on FTE.
looking good
__________________
Cody, Calgary
AB Chapter Leader
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 450hp 400, 4sp/205, 38" tsl's
  #11 (permalink)
Old 12-05-2006, 01:04 AM
351/400M on valve cover. Is there another 400?
__________________
  #12 (permalink)
Old 12-05-2006, 02:08 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation
Look again it should say 351M/400
And thats some pretty good preliminary numbers on that engine, nice job.
__________________
Rob
Dying's not so bad
It's living that will kill you off
  #13 (permalink)
Old 12-05-2006, 02:22 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold
Ford only gave letter designations to the various 351's as in 351C 351W 351M and then they changed the numbers on the 4th engine with the same bore/stroke combo AKA the 352.
Looking good Dan and Tim! When you get her all tweaked I know you will post some good numbers!
What are the black and purple lines? I can't read the designations.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #14 (permalink)
Old 12-05-2006, 02:26 AM
Actually Eric to be perfectly correct the 352 is not the fourth engine with that bore stroke, it's the first.
Oh and technically they are closer to 352cid anyway the actual displacement mathematically is 351.86.
__________________
Rob
Dying's not so bad
  #15 (permalink)
Old 12-05-2006, 02:31 AM
Torque1st's Avatar
Posting Legend
Yeah it was the first one produced! Little brother to my mighty 390!!!
And to be technically correct my 390 was closer to a 396 when punched. Same B/S as a Chevy 396. Mine ran better tho!
__________________
Tags
351 , 434 , area , chicago , cleveland , cs3130 , dan , daniel , dyno , lee , retrofit , roller , rollmaster , truck , trucks , tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
