Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #61 (permalink)
Old 12-16-2006, 09:15 PM
danlee's Avatar
danlee danlee is offline
danlee has a good reputation on FTE. danlee has a good reputation on FTE.
Quote:
Originally Posted by havi
I don't want to hijack. 2v headers sit lower than 4v headers, then right? Does Sanderson shorten the tubes on a 2v to compensate? Sandersons, for the most part, hug the block, don't they?, what tranny are you using? clearance issues there? Sorry, hijack over. I've been following this build for quite some time. I love it. To all the naysayers about the 351M/400 being a boat anchor, I love to prove them wrong. You guys are truly putting the 400 into greatness. Rock on.
I just checked the Sanderson website. They list the both the FC-2, and FC-3 headers for both the 2V and 4V heads on a 351C in a '53 and up F100. Mine are the FC-3s. They are all block huggers. I am using a C6. The right FC-3 header exits above the starter. Since I have a 400 block they are just exit a bit higher. I suppose by the same logic these headers on 2V heads will be a bit lower.
BTW they are 1 7/8" tubes.
I thought that there was some difference between the header bolt locations and the ports locations on the 2V and 4V heads. I know that CHI made the bolt locations compatible with most headers.
  #62 (permalink)
Old 12-16-2006, 09:28 PM
dkstuck dkstuck is offline
dkstuck is starting off with a positive reputation.
Correct me if I'm wrong,
2v-4v bolt pattern same,, only difference is the port size. 4v bigger hole.
  #63 (permalink)
Old 12-16-2006, 09:32 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a very good reputation on FTE. arctic y block has a very good reputation on FTE. arctic y block has a very good reputation on FTE.
Sound like talking to Grasshopper
__________________
62 UNI Wide Window SWB 390 C6
66 F350 Flat Bed Hi Pro 427 4 speed
7 4X4 Rangers 84 - 89
55 Fairlaine Town sedan 272 Ford O Matic
Show all the luv ya can while ya can. Or one day ya may be alone
Don't just Modify it Fordifiy it
  #64 (permalink)
Old 12-16-2006, 09:44 PM
danlee's Avatar
OK, I'm confused. The bolt patern is the same. The 4V port is larger, and taller. The 4V headers will fit the 2V heads. It is CHI 3V heads where the ports and the bolt holes are raised, so that all headers fit.
  #65 (permalink)
Old 12-16-2006, 10:05 PM
TMI's Avatar
TMI TMI is offline
TMI is starting off with a positive reputation.
If I was at the shop, I have some gaskets to compare. But I am pretty sure the 2V & 4V bolt pattern is the same. 4V is just bigger, but yet I think it is centered. The CHI 3V head require the 4V headers, just that the ports will be located in the upper part of the header. The 2V header covers the upper part of the CHI port. I can get some pictures of gaskets on the heads to see the difference.
__________________
Tim
  #66 (permalink)
Old 12-16-2006, 11:14 PM
havi's Avatar
havi havi is offline
Amateur User
havi is gaining momentum as a positive member of FTE. havi is gaining momentum as a positive member of FTE.
makes sense to me...to clear the taller port of a 4v header, right? While at the same time 2v headers will still fit evenly on a chi 3v head. I'm actually guessing.
__________________
The going, the journey, should be the objective of a trip in a built old Ford, the destination always secondary.
  #67 (permalink)
Old 12-17-2006, 12:48 AM
garypettengill's Avatar
garypettengill garypettengill is offline
garypettengill is gaining momentum as a positive member of FTE.
The bolt patterns are the same. I have a set on my 400, sanderson sends what they refer to as an adapter plate for them to fit to 2V head port size. The adapter plate is nothing more then a copper gasket with the ports cut to fit the 2V head. Bolts right up, I love 'em. BTW I currently running a C-6 and a married transfer case.
  #68 (permalink)
Old 12-19-2006, 10:30 AM
apachetech apachetech is offline
apachetech is starting off with a positive reputation.
We will see how the headers go Tim. I like the flow of the 1 3/4 in but I see what you are saying on normal driving. I still have lots of time before I need to make that decision.
__________________
434 cu in Stroker build in progress!!
  #69 (permalink)
Old 12-20-2006, 01:03 AM
Brian S Brian S is offline
Brian S is starting off with a positive reputation.
I've been wondering about some of the parts that interchange. If the rollmaster timing set up fits the smaller diameter 351W snout, can I assume a different set is required for the 335 series cranks? How about the H-balancer? Is it a W or C part?
I know reduced base circle cams for 335 series are the most common from manufactures, How are you able to use a standard HR cam in a 400 using OEM lifters? Is it an M-block vs Cleveland thing?
The reason I mentioned the wide LSA is because I have an article in my Files section that showed changing only the separation angle from 108 to 112 netted a peak 24HP increase on dyno. I wonder if this would be consistent with a desktop dyno program.
What was the reasoning behind the 224/244 split in duration? I can't say I've seen another cam with such a large difference.
Was there any indication as to why the head gasket blew?
When comparing header primary diameters I've always gone by OD. To avoid confusion, which is correct?
I was under the impression the Sanderson headers were 1-7/8.
What carburetors were tested other than the 775 Demon?
Are the 3V CHIs 218s the same heads used on the 360 Boss and the 434 Pantera engines dynoed earlier this year?
25-26 ign. doesn't seem like much. Does this indicate an efficient chamber design or could it mean the dynamic compression is too high? I wonder what retarding the cam 4-6 degrees would have done to raise the RPM peaks. My guess would be 300-450.
Take you time answering, I'm not going anywhere.
__________________
<!-- No promotion in sigs please. -->
  #70 (permalink)
Old 12-20-2006, 09:01 AM
danlee's Avatar
[quote=Brian S]
Increasing the separation angle from 112 to 114 reduces the overlap and increases the torque at low RPM, there is a small loss of peak HP.
This was a result of simulation. I ran iteration testing to select maximum area under the torque curve, keeping the peak power in the same RPM range. The results produced a cam with lobes similar to what I have, but the LSA was 117.5 degrees. I found that I was not able to get this cam at a reasonable cost, because it would have to be ground from a billet and heat treated. I was able to get close to the desired lobes at a 114 LSA from Comp Cams.
The answer that I got was that it was too lean. It must have occurred during the EFI tuning.
Sanderson's spec is 1 7/8" tube, I wll check to see if that is OD or ID.
The CHI heads are very efficient chamber design. The dynamic CR is quite high at 8.48:1, but this should be OK for alloy heads.
The simulator indicates that retarding the cam 4 degrees raises the RPM peaks a few hundred RPM. However the sim also indicates higher peak HP at a higher RPM than we are getting. There appears to be a small discrepancy in the torque figures between simulation and measured. There also appears to be another discrepancy in the RPM between sim and measured. These discrepancies compound in the HP calculation.
QUOTE]
  #71 (permalink)
Old 12-20-2006, 10:51 AM
TMI's Avatar
TMI TMI is offline
[quote=Brian S]I've been wondering about some of the parts that interchange. If the rollmaster timing set up fits the smaller diameter 351W snout, can I assume a different set is required for the 335 series cranks?
If you use a 335 series crank, then the typical Cleveland chain will work.
Since this was a Windsor crank, it was also a Windsor balancer, if you use a Cleveland crank, then the Cleveland balancer will work. That was one of the issues I noticed in the "Hot Rod" magazine article, they offset ground a 400 crankshaft, but used a 302 balancer. This should not fit naturally, extra machining or somthing.
Tall block
The 360 Boss was a 218-3V, if I remember the Pantera was also a 218-3V.
QUOTE]
__________________
Tim
  #72 (permalink)
Old 12-20-2006, 01:50 PM
TMI's Avatar
TMI TMI is offline
Horse Power Update
Horse Power update!!
We currently have a 351C on the dyno, we were given a warning from the local police about not having the mufflers on.
So we installed the mufflers, a pair of 5" mufflers from a semi.
On this 366 HP engine we lost 13 HP, and 20 torque.
Now Dan's 434 was run with mufflers on the whole time, how much increase is there without???
I would have never thought there was that much back pressure.
__________________
Tim
  #73 (permalink)
Old 12-20-2006, 08:10 PM
danlee's Avatar
The sim indicates 27 HP difference between large tube headers with mufflers and without on my 434.
One area that we didn't look at on my motor is head flow. My simulations use the CHI published data. If the head flow is not as good as published, there could be some loss across the RPM band.
  #74 (permalink)
Old 12-21-2006, 04:13 AM
grclark351 grclark351 is offline
grclark351 is starting off with a positive reputation.
the length and diameter of exhaust tubing plays a big role too, the more volume the system can hold, the longer the engine can rev with less backpressure before the pipes fill with smoke and limit the engine.
have you seen this? http://www.broaderperformance.com/mu...flow_tests.htm
  #75 (permalink)
Old 12-21-2006, 11:12 AM
beartracks's Avatar
beartracks beartracks is offline
beartracks is starting off with a positive reputation.
Somehow I missed the intake manifol type/manufacturer. Looks like a single plane. Does the engine make enough torque down low to work on a street truck auto with say a 2300rpm stall?
__________________
Bear Tracks
1977 F-100 Ranger XLT,400,C6,GV
Mod's Listed in Gallery
Click Here To Help Support FTE
Tags
351 , 434 , area , chicago , cleveland , cs3130 , dan , daniel , dyno , lee , retrofit , roller , rollmaster , truck , trucks , tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
