Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 12-05-2006, 02:34 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation
Never was much of a fan of the GM POS 396
__________________
Rob
Dying's not so bad
It's living that will kill you off
  #17 (permalink)
Old 12-05-2006, 10:30 AM
bmc69 bmc69 is offline
bmc69 is starting off with a positive reputation.
Looking GOOD Dan!...
  #18 (permalink)
Old 12-05-2006, 11:28 AM
job1bf job1bf is offline
job1bf is starting off with a positive reputation.
look at that fat TQ
it is so flat, I don't think you can even call it a curve!
looking forward to more details...
  #19 (permalink)
Old 12-05-2006, 08:59 PM
roushracing617 roushracing617 is offline
roushracing617 is starting off with a positive reputation.
Tim, are you guys going to do a video of Dan's 434 for your web-site?
  #20 (permalink)
Old 12-05-2006, 09:17 PM
TMI's Avatar
TMI TMI is offline
TMI is starting off with a positive reputation.
Yes we are planning on it.
__________________
Tim
  #21 (permalink)
Old 12-07-2006, 08:35 PM
dkstuck dkstuck is offline
dkstuck is starting off with a positive reputation.
Awesome!!!!
  #22 (permalink)
Old 12-08-2006, 03:08 PM
roger dowty roger dowty is offline
roger dowty is gaining momentum as a positive member of FTE. roger dowty is gaining momentum as a positive member of FTE.
I've been, not so patiently, waiting for some #'s with injection.....and a decent distributor- wondering if the bad one was one of the hei units. I'm about to trash the cheap one I have on the wheezer.
__________________
'77F1504x4, '75 f250crew4x4, '79 Bronco 429, '83 bronco, '72 Torino with 351cj, 70 1/2 falcon, 75 stangII. all projects, 2 on the road. One pissed off wife!
  #23 (permalink)
Old 12-09-2006, 04:54 PM
danlee's Avatar
danlee danlee is offline
danlee has a good reputation on FTE. danlee has a good reputation on FTE.
I have some bad news to report on the EFI 434. We were not able to reproduce the numbers that we got with the carb, then we lost a head gasket.
I am going to head back home without my motor. Tim is going to replace the head gasket, and dyno it again with a carb. I will install the EFI, when I get it home.
It appears that the EFI setup is barely equivalent to a 650 CFM carb. If I want to get more out of it, then I need to improve the TB/intake system. First I have to find where the restriction occurs.
  #24 (permalink)
Old 12-09-2006, 07:27 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold
That is bad news. That looked like a sweet setup.
I wonder what took out the head gasket? Maybe Tim will be able to tell.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #25 (permalink)
Old 12-09-2006, 07:44 PM
danlee's Avatar
The head gasket might have started leaking when we had some initial timing issues.
The setup is still OK for moderate performance or a smaller motor. If some restrictions can be eliminated, it could do better. The Lightning MAF only supports about 770 CFM, which is surprising. I am going to investigate that as well as the pressure drops.
  #26 (permalink)
Old 12-09-2006, 08:16 PM
JBradley500's Avatar
JBradley500 JBradley500 is offline
JBradley500 is starting off with a positive reputation.
Do you think you may have lost power with the EFI because of a head gasket issue during dyno run?
__________________
Engine-410ci (9.8:1), CHI heads, 219/222 Roller Camshaft, Ceramic Fenderwell Headers, Pro-Systems Carb, Edelbrock Intake, Super Sucker, Comp Cams Stainless Rockers.
Driveline-T18 4 speed, NP205, Dana 60 Front, 14 Bolt rear & 5.13 gears are in the Future.
Tires-39.5x18 Boggers
  #27 (permalink)
Old 12-09-2006, 09:38 PM
danlee's Avatar
Quote:
That is a possibility! Tim is going to fix the head gasket and dyno it with a carb. Then I will take it and try to match the dyno air flow and manifold vacuum with a decent fuel/air mixture.
  #28 (permalink)
Old 12-10-2006, 01:45 PM
grclark351 grclark351 is offline
grclark351 is starting off with a positive reputation.
what brand/part number head gasket was that? i read quite a few posts of the "top shelf" exotic graphite laminated steel shim yada yada yada brand gaskets failing quickly after a build. i like the Fel-Pro 8347PT-1, they list it as an "economy" gasket but it's my go-to favorite. i ran an 11.5:1 rattling Cleveland on goat piss pump regular in between stops at the airport and those head gaskets never gave up!? some guys get irate about using any coating on a head gasket, i've used them with aluminum spray paint, spray copper and dry, never had a failure any way i installed them. the spray coating even made it possible to re-use a pair once when a rod bearing overlapped 3 days into a build. the rods were not checked out and i ran them as-is. Doh. but the head gaskets ran again without issue!
i'll be surprised if you say they were the cheap Fel-Pro Blues!?
  #29 (permalink)
Old 12-10-2006, 04:51 PM
factory594x4 factory594x4 is offline
factory594x4 is starting off with a positive reputation.
How did you get a 4.25" stroke? What is the CR?
  #30 (permalink)
Old 12-10-2006, 06:13 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a very good reputation on FTE. arctic y block has a very good reputation on FTE. arctic y block has a very good reputation on FTE.
Quote:
Yes inquiring minds need to know
__________________
62 UNI Wide Window SWB 390 C6
66 F350 Flat Bed Hi Pro 427 4 speed
7 4X4 Rangers 84 - 89
55 Fairlaine Town sedan 272 Ford O Matic
Show all the luv ya can while ya can. Or one day ya may be alone
Don't just Modify it Fordifiy it
Tags
351 , 434 , area , chicago , cleveland , cs3130 , dan , daniel , dyno , lee , retrofit , roller , rollmaster , truck , trucks , tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
