Using E85 Fuel
Originally Posted by billj6
What is the ECU, why does it have to be reset and does it reset automatically? I too have a flex fuel '99 Ranger and have never burned E85. It is just now coming to the western Pa. area.
it DOES NOT have to be manually reset.
Originally Posted by RangerPilot
...........you'll need to disconnect your battery to reset the ECU for E85.
I concur, it shouldn't take an ECU reset. I think I've read posts of people who switched after a long time on gasoline and had issues because the ethanol "cleaned out" their fuel system, clogging their fuel filter. Might just be something to watch out for.
Also, I don't think most people report a seat-of-pants power loss. But your fuel mileage will decrease. There are several threads in the "Alternative Fuels, Hybrids, and Mileage" forum that address these concerns.
-Jim
-Jim
Originally Posted by fordboy_52
my highway milage dropped from 18 to 13 when i went to e85. it was also priced at 1.77 where reg was 2.32
72% drop in milage
76% drop in fuel price
I actually did worse on e85...
Matt
72% drop in milage
Matt
27% drop in MPG
23% drop in fuel price
How did you get 72% and 76%??????
This thread in the Alternative Fuels forum debates E85 rather thoroughly.
https://www.ford-trucks.com/forums/5...flex-fuel.html
I saw those goofy numbers . 76% loss of mil(e)age would quickly imply less than 9 mpg; just do a visual sanity check on math. However, and at any rate, a little more calculating is needed to determine the benefit/disbenefit of burning alcohol.
*How to calculate percentage changes:
((final value ) - (initial value)) / (initial value)
Todays math assignment (calculators allowed if over 12 YO):
Esther drives her Chevy Malibu only to the grocery store, the doctors office, her dentist for false teeth, and to church on Sunday morning. On her last fill up, she drove 375 miles and it cost $52.69 to fill the tank. What was her average fuel cost per mile for the last 375 miles driven?
I'm guessing that he meant to say that the price of ethanol was 76% that of gasoline ($1.77/gallon / $2.32/gallon = .763) and that his mileage running on ethanol was 72% of his mileage running on gasoline (13mpg/18mpg = .722). Effectively, he stated the absolute percentage, not the percentage change (or difference).
-Jim
-Jim
So, what happens if you put the E85 stuff in an older fuel injected vehicle? I.E. an '88 Ranger 2.9?
I don't know if it will get to Cali anytime soon but I need to be aware if I should run into the stuff.
Naturally I would assume that it would be marked on the pump, but stranger things have happened . . .
Rich
Rich
It is suggested however, to allow the fuel tank to get as low as possible before swithing back and forth. As far as putting it in a vehicle that isn't supposed to run on E85, the pcm will read lean and ask for even more fuel, setting codes and driveability problems.
