73-79 F-150 Estimated Curb Weight - Ford Truck Enthusiasts Forums
Old 12-03-2006, 06:03 PM
Nightrain Nightrain is offline
Nightrain is starting off with a positive reputation.
I was reading an article a few minutes ago on the net that stated the new standard cab/short box 4x4 F-150's have a curb weight of ~5,200lbs.
That got me curious of how much things have actually changed...
What is the estimated curb weight of a 4x4 73-79 F-150?
Let's see how much weight they've took off in 30 years.
Nightrain
Old 12-03-2006, 06:11 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Have no ref for curb weight, but GVW (Gross Vehicle Weight) on 1979 F-150's was between 6,050 to 6,400 pounds. My ref has no breakdown on 4x2 opposed to 4x4.
Old 12-03-2006, 06:51 PM
1973F250CREW's Avatar
1973F250CREW 1973F250CREW is offline
1973F250CREW is gaining momentum as a positive member of FTE.
Not sure about my curb weight, but my GVWR is 7,700 lbs.
Old 12-03-2006, 07:07 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
I'd say ....About 4200 lbs with both fuel tanks filled
Old 12-03-2006, 08:30 PM
Doesn't seem like they've changed a whole heck of alot, then.
I figured at least 5,200-5,500lbs., but I guess I was pushing it.
Thanks for the figures!
Nightrain
Old 12-03-2006, 08:43 PM
Cutls67's Avatar
Cutls67 Cutls67 is offline
Cutls67 is starting off with a positive reputation.
I know I have a 250 but I ran across the scales after emptying my bed at a salvage yard and it was about 5,200 lbs. But like I said my is a heavy duty F-250
Stephan
Old 12-03-2006, 09:03 PM
mudslingur mudslingur is offline
mudslingur is starting off with a positive reputation.
my 77 4x4 ford's rigistation paper says it weighs 5600 but that is the paper talking.All i know is these old trucks are solid steel,so they have to weigh a little more
Old 12-03-2006, 09:45 PM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
Quote:
Stephan
Similar here. Mine weighed 5300 with a buddy and I in it. The only difference between my truck and an F150 is the 8 lug outters and the dana 60 rear.
Old 12-03-2006, 11:29 PM
Nighteyez's Avatar
Nighteyez Nighteyez is offline
FTE NorCal chapter LDR
Nighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputation
Hmm,
My truck was weighed by the previous owner in order to get the current DMV fees, and it weighed 4760 with tanks empty. This is a F250 with 460 C6 and Dana 70 rear end (1976) 8 bolt axles, and gvwr of 8000.
Jim
Old 12-04-2006, 02:39 AM
1978fordf250 1978fordf250 is offline
1978fordf250 is starting off with a positive reputation.
my 1979 f-150 with 3inch bodylift and 35's (whitespoke steel rims) weighs 4600 with quarter tank of gas in it. Also my 78 f-20 strait cab long bed weighs 4900 with 1/2 tank of gas. I know this because i work 2nd shift at a stone quarry and i weighed both of the trucks.
jimmy
Old 12-04-2006, 09:04 AM
77460f150's Avatar
77460f150 77460f150 is offline
77460f150 is starting off with a positive reputation.
My 77 F150 4X4 short box with 460 C-6 weighed in at 5080 lbs. The title said it weighed 5100 lbs. In Michigan if your truck weighs over 5000 lbs. it is considered a comercial vehicle and the cost of plates for a year is almost double of that of a non-comercial vehicle. So, when I went to get tags for it and the Sec of state informed me of this I told them I didn't think it weighed that much, because I have another 77 short box that is the same (460 C-6 etc...) and the title said it weighed 4575 lbs. They told me to go get the truck weighed and bring them a certified receipt from the scale and they changed the title weight based on this. I took it home removed the rear bumper, tail gate, one of the dual batteries, and made sure the fuel tank was low. It weighed in at 4870 lbs. and ran out of gas sitting on the scales. ( I guess that was about as low as I could get it.) Took the certified scale receipt back to them and they issued me a new title for that weight. -Ed
Old 12-04-2006, 03:04 PM
73FOMO's Avatar
73FOMO 73FOMO is offline
73FOMO is gaining momentum as a positive member of FTE.
Heavy trucks....my 73 lwb, 302, auto c4, 4x2 weighs 3900# unloaded.
Old 12-04-2006, 03:10 PM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
We weighed a 1979 F-250 4x4 with a 100lb weight bracket on front and it weighed 5200. And we weighed a 1997 F-150, 4x4 short bed and it weighed more than the 250 long bed at 5350. More like how much weight have they added not lost. Just look at the Mustangs too, heavier with every body change since 1979. An 07 Shelby weighs almost 1000lbs more than a 1993 notch.
Old 12-04-2006, 06:59 PM
Man!!
I had figured these trucks would weigh a ton of bricks more than a new F-150.
Geeze!!
Nightrain
Old 12-04-2006, 07:47 PM
460's Avatar
460 460 is offline
460 is gaining momentum as a positive member of FTE.
I'm not sure where the newer trucks gained the weight though? They lost a lot of metal and gained many plastic parts... so what weighs more?
Chevy is the same way - the newer trucks weigh more than comparable model older trucks.
1989 f150 and bronco curb weight Nally427 1987 - 1996 F150 & Larger F-Series Trucks 1 08-11-2012 11:37 PM
76 F-150 curb weight Y82WS6 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-27-2012 11:24 PM
What is the curb wieght for 1999 F150 supercab 4x4 jdhudall 1997 - 2003 F150 2 11-28-2011 05:50 AM
Curb Weight of a '94 F-150 5.8 ex cab? TS6034 1987 - 1996 F150 & Larger F-Series Trucks 4 09-05-2010 10:54 AM
what is my curb weight??? nstueve 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 08-27-2010 05:53 PM
Tags
1979, 77, cab, california, curb, dmv, f150, f250, ford, gross, gvw, ranger, regular, vehicle, weight, weights
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
