Tilt Front End for '55 ford
Big job ahead of you. I don't know if you have seen many, but the steel ones I have seen all cut their fenders because of the fender curl by the door jam. the best ones (least amount of body rub from the fender/hood unit moving) had welded the fenders to the hood to make it a one piece unit. Added electric hydraulics to lift. Looks good when done right. I would appreciate it if you could share pictures as you progress.
good Luck
Dennis
55SSmokum
good Luck
Dennis
55SSmokum
on
I can't offer any technical help just advice from a fiberglass install. You're gonna have to have hydraulics or electrics to lift it...or a helper. The ones I've seen have had the fenders and hoods seperated by spacers to maintain their look. The fenders will have to be cut...either down low to clear the cowl or up higher and the lower sections attached permenently to the cab.
I opted for fiberglass and it's much easier... I detailed that install... go to http://jniolon.clubfte.com and look in the left frame. it might give you some ideas on what 's involved...
good luck...
john
good luck...
john
>involved...
>good luck...
>john Hey I would liketo thank you for your help and I'm following your web page and your progress with your truck, you hav been doingalt of work on your own, thanks for your help and keep up the good work, take care.
>involved...
>good luck...
oldmanrvr5
16
12-13-2008 11:10 AM
94f2507.3td
09-22-2005 02:43 PM
