Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 12-02-2006, 08:38 PM
bio-d bio-d is offline
Garage is empty, add now
bio-d is starting off with a positive reputation.
Question SVO heater line size?
I'm installing a Plant Drive SVO kit in my 87 6.9, using a 26 plate heat exchanger, Vormax filter/water separator and a 10" Hot Fox oil pickup.
They normally use 3/8" hose teed into the heater hose. Have any of you used 1/2" hose in your installations? I expect to be driving in very cold weather.
  #2 (permalink)
Old 12-02-2006, 09:15 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
I have a kit from Greasel that uses ˝ inch lines. The system is a hose on hose with a transmission cooler used as the heat exchanger is the front tank and a Racor 6120 with heater installed in the clear filter bowl. Filter on my 95 powerstroke. I added an arctic fox mid ranger inline fuel warmer to the standard kit from Greasel. I would recommend you checking out the arctic fox fuel heaters.
I have had no fuel related issues with this setup.
Note: Greasel changed their name to Golden fuel system.
http://www.goldenfuelsystems.com/pro...stems_ford.php
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #3 (permalink)
Old 12-02-2006, 09:41 PM
Thanks Willbd. I wasn't sure if all the restriction of the heat exchanger would negate the larger hose size.I saw some of the more advanced Hot Fox tank pickup heater units after I had already ordered mine. They are similar to the basic coolant in- coolant out and fuel out units like mine except they have a fourth connection to connect to an external heat source.
I have another question: Where's the best location for my fuel temp sensor?
I have a Vegtherm just prior to the IP. I was going to put it just after the Vegtherm.
Mike
  #4 (permalink)
Old 12-02-2006, 10:39 PM
I have don't have a fuel temp sensor on my system. I switch over when the engine gets up to temp. I have checked the fuel temp with a thermometer and my fuel is @ 165 F down stream of my arctic fox heater. This is before the fuel enters the 18 feet of greasel hose on hose fuel line.
__________________
Bryan Will
Tags
arctic, diameter, fox, heater, midranger, svo, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
