I need help
Old 12-02-2006, 07:28 PM
actrojan11's Avatar
actrojan11
actrojan11 is offline
I need help
I just purchased a 2001 F-150 and today I noticed that the odometer is not lighting up. Also noticed that there is not a continuous stream of power thru one of the power points and the other will not work at all. One other thing to go along with this is it started skipping some. It only skipped this morning. I have driven the truck several other times today and did not notice the skipping. The odometer has not worked any of the times. It does start to work after the truck has been running for a while. Sorry so lone but any ideas?
Old 12-02-2006, 10:46 PM
Tomcat7742's Avatar
Tomcat7742
Tomcat7742 is offline
I wish I had an answer for you but I'm facing a similiar issue. Every once in a while, it's not often, my odometer does not light up. Usually it will go away but once I hit a good bump it will come back on?
- Chris
Old 12-03-2006, 12:13 AM
macjb's Avatar
macjb
macjb is offline
Old 12-03-2006, 09:16 PM
Tomcat7742's Avatar
Tomcat7742
Thanks' macjb, I'll defenitly have to try that.
- Chris
