Oil pressure sending unit - Ford Truck Enthusiasts Forums
Old 12-02-2006, 07:00 PM
mrwolf mrwolf is offline
mrwolf is starting off with a positive reputation.
Howdy
My gauge shows no oil pressure at all,
Can anyone tell me where the oil pressure sending unit is located so that I can change it?
Thanks
Old 12-02-2006, 07:19 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
All the way to the rear of the engine, slightly to the passenger side of center.
Sticks straight up with a wire plugged to the very top.
This is the rear of the engine, you can see a brass nipple sticking up from below the turbo outlet. That is the location of the stock oil pressure sending unit.
Old 12-02-2006, 08:12 PM
bc6.9 bc6.9 is offline
bc6.9 is starting off with a positive reputation.
Come on Dave, no ones engine looks like yours ....mrwolf is a newbie , he's probally more confused now than ever!
Old 12-02-2006, 08:29 PM
1991f250 1991f250 is offline
1991f250 is starting off with a positive reputation.
Does the oil pressure switch put out a ground with oil pressure and an open with no oil pressure? Has anyone ever measured it?
Old 12-02-2006, 08:38 PM
No, I've never measured it but have replaced one my 86, easy to re & re....one of the things you'll read, is that the stock gauges for the IDI's are not very reliable at all and you want any real readings, you should go with after market gauges.
Old 12-02-2006, 08:48 PM
roamer37's Avatar
roamer37 roamer37 is offline
roamer37 is starting off with a positive reputation.
If you ground the wire to the Oil Pressure switch it will make the gauge read max oil Pressure with the wire off it will read no oil pressure!
Old 12-02-2006, 09:06 PM
Thanks.. I will check it out in the morning
No wonder I did not find it, the turbo probably hid it
Old 12-02-2006, 10:55 PM
bio-d bio-d is offline
bio-d is starting off with a positive reputation.
I have an aftermarket ATS turbo in my 87 6.9 and I had problems getting at the stock sender. I put a T into the oil supply line to the turbo. Its very accessible. I put in another T for a Napa sending unit. The stock wire just reaches to it. Instead of close nipples I used air compressor fittings. They are short but have a hex center so you can tighten them.
Mike
Old 12-03-2006, 01:28 PM
The oil pressure gauge works by resistance.
When I was using the stock gauge I found unplugging the electrical connection and the reinstalling it could and would change the pressure reading.
That is why I went with a mechanical oil pressure gauge.
Sorry I did not have the oil pressure location circled, but that is the only picture I have uploaded that you can see the back of the engine.
Old 12-03-2006, 03:24 PM
Thanks guys,,I found it and put the new one on... works great now
The funny thing is that it is located right on top of the turbo in plain sight.
Thanks to Daves picture I was able to track it down and the tube went to the top
of the turbo and there it was... right in plain sight
I was looking all around the block near the oil cooler and filter, thats why I did not find it
Anyways..thank you for all your help
Old 12-03-2006, 10:25 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Dave's pretty proud of those pics, likes to flash them out all the time... Of course, he should be... I'd about swear he pulls them out like pics of kids...
Old 12-04-2006, 10:06 PM
Dave, we're just jealous ....not all of us have a spanking new IDI ....you keep showing us pics of your baby , we understand....your a proud papa!
Old 12-05-2006, 08:49 AM
fellro86's Avatar
Darn right I'm jealous and I hope to use some of his ideas in the future... no disrespect intended in my comments... just joking around...
Old 12-05-2006, 09:34 PM
I have found a picture is worth two pages of typing.
I just took pictures of everything I had a hard time telling someone how to find before I had my engine out.
I have found I should have taken time to take a few more pictures though.
There have been several asked that I did not have pictures of here lately.
Would you all feel better if I use this one from now on?
But since the top of the engine is missing, it does not really tell you where to look or the fact you can't really see it that well either.
LMAO.....I love it.
I got a little more fuel to it now, running about 24 PSI boost, and still a little black smoke. Passes everything but a fuel pump. The blended winter fuel dropped my MPG by 3 miles to the gallon. Boy these 15 degree mornings sure do make it fun to drive though, that cold air sure does agree with the engine.
Old 12-05-2006, 09:43 PM
fellro86's Avatar
Oh, by all means, keep us posted on how it runs with the new changes. That sucks that it dropped that hard on mileage.
oil pressure sending unit drewdole Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 12-03-2009 12:10 AM
Ford F150 No oil pressure Michelle A 1997 - 2003 F150 5 05-21-2004 02:09 PM
Oil Pressure sending unit? teederj2002 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 10-21-2003 01:06 PM
oil pressure sending unit AggiePSD 1987 - 1996 F150 & Larger F-Series Trucks 13 07-28-2002 06:45 PM
Oil Pressure Sending Unit Location cinnpass 1987 - 1996 F150 & Larger F-Series Trucks 3 10-26-2001 10:29 PM
Tags
05, 6bta, 73, cummins, diesel, ford, idi, location, oil, pressure, sending, truck, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
