F150 Starter has me stumpt?
Old 12-01-2006, 11:57 PM
amisuraca's Avatar
amisuraca
amisuraca is offline
Ok, guys. I am new to this site but not to working on my own vehicles but this one has got me stumpt. I am trying to change my starter on a 2001 4.6L F150. I was able to get the two lowest bolts but how in the heck are you suppose to get to the top bolt? Does something else need to be taken off to get to it. I have tried from underneath and through the right wheel well and no dice. If someone knows how to do this I would be greatful. Thanks in advance.
amisuraca
Old 12-02-2006, 12:05 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
Hi and welcome to the forum
You just need to find the correct combination of extensions and socket to allow you to use a ratchet in front of the starter, in between the starter motor and the crossmember. If you have an air ratchet that makes the job much easier.
Old 12-02-2006, 12:29 AM
preppypyro's Avatar
preppypyro
preppypyro is offline
I found it really easy when I did mine. I had a long and a short extension and it seemed to work perfect under there. Once you do it once, it will be simple.
Old 12-02-2006, 08:06 AM
amisuraca's Avatar
amisuraca
Thanks guys but how are you accessing it as that is my problem. Are you accessing it from the bottom of the engine compartment or though the right front well well? Thanks again.
amisuraca
Old 12-02-2006, 08:30 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
From the bottom. Put the socket and extensions on the bolt and then put the ratchet onto the extension, in between the starter motor and the crossmember.
Old 12-02-2006, 08:36 AM
amisuraca's Avatar
amisuraca
Hmm, I just don't see any room to rachet at all. I am thinking I am going to have to pull something in order to get that top bolt off. Does the top bolt require a deep socket?. Thanks a bunch for you help Racerguy.
amisuraca
Old 12-02-2006, 08:38 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
I use a short socket. The key is to figure out which extensions will work best for you.
Old 12-02-2006, 09:07 AM
amisuraca's Avatar
amisuraca
OK, and this is the top bolt of three bolts right? If so I will give it a try.
Old 12-02-2006, 10:43 AM
ddrumman2004's Avatar
ddrumman2004
ddrumman2004 is offline
I used a combination of extensions and a universal joint on my 97 4.6 when I changed the starter. I accessed the top bolt through the wheel well after removing the wheel.
I cussed and swore at that starter.
Old 12-02-2006, 06:13 PM
amisuraca's Avatar
amisuraca
Thanks for all the help guys. I got it done. I was able to access that top bolt blindly with a long extention and a UV joint extender as well. I did not have to go through the wheel well but I had to have just the right length as there is just not much room to rachet. Thanks again for all the great help. I hope this thread helps others trying to change out there starter. I as well did a little cussing at the starter but I think what really worked was the prayer I said before my last attemp. Thanks all.
amisuraca
Old 12-02-2006, 08:21 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
Good to hear that you got it done
Old 12-03-2006, 12:05 AM
preppypyro's Avatar
preppypyro
Yeah im glad ya got er done too. The first time is the worst believe me!
tickle_me_moe
Bronco II
01-24-2006 10:49 AM
jcbmrizzo
20
05-05-2005 12:54 AM
Boss50
1997 - 2003 F150
11-13-2004 07:25 PM
fasteddie
07-23-2003 07:37 AM
SemperFiMac
06-25-2003 05:17 PM
Quick Reply: F150 Starter has me stumpt?
