leave runnning or shut down
I leave mine on. Its just a habit for me since we always leave our tractors/ big rigs or other heavy duty equipment idling. When I worked road construction a few years ago, we'd let dump trucks idle all day even in the heat of summer. The only thing it does is consume a little fuel. Its not the 70's anymore, wet slacking shouldn't be a problem.
This topic has been brought up in great discussion in the general diesel forum. It seems to be preferance.
The only problem i could see is if you have a 6.0 with the vv turbo on it. They say not to idle those things to long as sulfur builds up and prevents the vanes to move.
I let it run. Spare key on a separate key ring. Besides, as was said before, most engine wear is on startup. And depending on how it was driven prior to shutdown, the engine needs some idling to cool the turbo to reduce oil coking on the turbo. Driven hard or pulling then you need up to 5 minutes to cool the turbo. Or take the guessing out and get a turbo temp gauge (pre-turbo) installed and then you know the temp.
I agree with grinch, if you look in your diesel manual page 11 "it is recommended that a hot engine be allowed to operate at low idle for 7-10 minutes which would allow sufficient time for the turbocharged engine to cool down." Lots of good stuff in the manual. One interesting thing is it says both cold and warm start to wait 15 seconds and then drive away normally. One thing when in construction our mechanic said to leave equipment idling no lower than 1000 rpm to keep the oil pressure up. May be folk lore, I don't know.
I NEVER take the single key out of my ignition. My keyring with my keys ( house, work, truck ) are in my pocket and that is where they go back as soon as I unlock the running truck. I have been know to run into Wally me Dolly store for a half an hour or so with the truck running, esp durring cold months.
for those of you with key fob's you can cut the brown wire to the brain right by the throttle pedal and this will allow you to unlock and lock the doors with the fob while its running. dont forget you did it though if you ever need to reprogram a fob. if not it will not work.just wire it back up and re program.
I run a 140 mile delivery route with 72 stops each Monday. Each stop is about 1-2 minutes. I have measured fuel use with stopping engine each time and with leaving it running. Stopping the engine each time saves about 15% fuel. This makes sense when you think how many revs there are in 1-2 minutes and how many revs it takes to start the engine.
It may put a little more wear and tear on the engine but it does save a lot of fuel by shutting it down for all stops.
I drove big truck for 15 years over the road and I was always told to idle up so that the fuel didn't wash the cylinder walls clean of oil and wipe out the rings. With the old turned up mechanical pumps and oversized injectors this was a real problem but with our fuel systems I don't believe it should be a problem.
Dave
Dave
