Adding a little oil in the tank
on
1 Post
I'm curious since the new High Sulfar Diesel Fuel has come around here in california if it would hurt adding al ittle store bought vegatable oil in the tank before filling it up. I wonder because a gallon of corn oil is cheaper than a gallon of lucas fuel treatment.
Any suggjestions wehter or not this is a good idea. And how much would be a safe limit to add to a 05 6.0 with a 38 gallon fuel tank.
years back we used to run pure kero in the winter by adding 1 qt of 30w to 10 gals to lube up the fuel injection pump on our vw diesel and never had any problem with it. we started doing it after haveing a tank gell up almost fully. when skiing and haveing the temp drop to minus 40 with the wind chill ,closeing down the ski area. in lake plasid new york
veg oil i have to side with the other guys here that would tend to gell up or gum up the system
2 cycle oil and motor oil
I was reading on a Duramax forum that they use 1 gal. of 2 cycle oil. I never tried it because 2 cycle oil is kinda high. My uncle told me to add a quart of ATF to tank of diesel, he said it cleans injectors and lubricates fuel system. I have tried this and it quitens my psd a little. On the Duramax forum they talked about a quart of 30 weight oil. I have never tried it either.
Originally Posted by AndysFords
I think a gallon of veggie oil in 38 gallons isn't enough to hurt anything, but then what do I know, I already burned up one IP burning 100% unheated oil!
jimbo
The will stay mixed. I have a jar that has been sitting on my porch for a month of veggie oil and diesel 50-50, and has not seperated yet. You have to use NON-Hydrogenated oils only.
jimbo
