You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I'm curious since the new High Sulfar Diesel Fuel has come around here in california if it would hurt adding al ittle store bought vegatable oil in the tank before filling it up. I wonder because a gallon of corn oil is cheaper than a gallon of lucas fuel treatment.
Any suggjestions wehter or not this is a good idea. And how much would be a safe limit to add to a 05 6.0 with a 38 gallon fuel tank.
__________________
1991 HD F-250 XLT Lariat
Fire Breathing 460 V-8 E-4OD
RIP 94' F-150 4X2 5.0 MAF 4R70W Super Cab Shorty Green W/ tan accent 2" front lift Flowmaster 40 3-20-94 to 6-8-05 First truck and I hit a bridge reaching for the cellular
Can you buy Biodiesel in your area? If so I would buy Biodiesel or a blend of Biodiesel.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Mixing UN-HEATED vegetable oil with diesel is never a good idea.................
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
years back we used to run pure kero in the winter by adding 1 qt of 30w to 10 gals to lube up the fuel injection pump on our vw diesel and never had any problem with it. we started doing it after haveing a tank gell up almost fully. when skiing and haveing the temp drop to minus 40 with the wind chill ,closeing down the ski area. in lake plasid new york
veg oil i have to side with the other guys here that would tend to gell up or gum up the system
I was reading on a Duramax forum that they use 1 gal. of 2 cycle oil. I never tried it because 2 cycle oil is kinda high. My uncle told me to add a quart of ATF to tank of diesel, he said it cleans injectors and lubricates fuel system. I have tried this and it quitens my psd a little. On the Duramax forum they talked about a quart of 30 weight oil. I have never tried it either.
I think a gallon of veggie oil in 38 gallons isn't enough to hurt anything, but then what do I know, I already burned up one IP burning 100% unheated oil!
Also, lots of truckers use to put a quart or two of ATF in with every fill up, however since they started dyeing off road red, some could get a ticket, it would be kind of hard to prove it was ATF not offroad.
The problem is they won't stay mixed. Pure veggie oil won't break down in diesel. They will seperate just like 30 weight and water.
jimbo
__________________ WANTED: Someone to go back in time with me. You'll get
paid after we getback. Must bring your own weapons.
Safety not guaranteed. I have only done this once before. www.jimkidd.com
The will stay mixed. I have a jar that has been sitting on my porch for a month of veggie oil and diesel 50-50, and has not seperated yet. You have to use NON-Hydrogenated oils only.
O.K. I was going of bad information that I read on this forum somewhere along the way. I think it was a bashing Diesel Secret thread.
jimbo
The problem is knowing EXACTLY what kind of oil it is! I have restaurants that use both, and it gets mixed together by the time I get it.
Using UNHEATED veggie oil is not recommended for any diesel engine!
FABMANDELUX.
__________________
