Boost sensor
Boost sensor
Hi all,
Here is the sitsuation. My truck now seems to not want to tach out in the higher gears 4 and 5th. Would it possible that my boost sensor is bad or would you think it is oil pressure regulator? It seems to run fine except it doesnt seem to respond like it used to. It has only been happening last 2 weeks. I have a 1994 powerstroke with 212,000 miles. I checked the EBPV and it seem to be functioning normally. Any ideas?
I checked the fuel pressure today and it was 45lbs at idle. So sounds like i can rule my power loss due to a fuel problem out. It must be a weak HPOP. I dont have a way to test this. I will probably have to take it to the shop for some diagnosis $$$$. Hate spending money to figure out what is wrong with my truck....ugh.
Have you changed the fuel filter latley...If not change it and clean the FPR screen while your at it. Its a screen just inside the hole about 1/3 the way down the inside of the filter vessel(right hand side)). Use a q-tip and clean it out good.
Also you can unplug the IPR sensor and test drive your truck. See if that makes any difference.
I think (not certian)you could do the same with the map sensor just to rule it out also.
Unplugging both will cause a CEL but will send a default value to the pcm...thus telling you if the sensor is bad.
Low and behold it was the damn EBPV not opening all the way. It is malfunctioning, cannot afford to fix at the moment with christmas so close, so I just had the damn thing wired open. Should be a little slower to warm up in the morning, but at least I have my power back now. The mechanic said I need a pedestal, anyone have one they want to sell. 1994 Powerstroke.
Benny76
1999 to 2016 Super Duty
12-17-2016 11:01 AM
superstroked6.0
10-23-2016 06:18 PM
menmy02x
09-26-2016 08:42 AM
