Fuel Consumption @ idle - Ford Truck Enthusiasts Forums
Old 11-30-2006, 11:48 AM
OBXTucker OBXTucker is offline
OBXTucker is starting off with a positive reputation.
What's the burn rate of our 6.0's (gph) while sitting at idle in the parking lot (or where ever)?
Just curious how much fuel I burn letting it idle for 20 +/- minutes in the morning (multiplied over time!).
Thanks!
Old 11-30-2006, 12:04 PM
albran's Avatar
albran albran is offline
albran is starting off with a positive reputation.
me thinks it burns A LOT
I did a test this summer, coming out of the Eisenhower tunnel in Colorado put transmisson in neutral and reset MPG to 00.0 coasted for at least 10 miles, breaking at 80 mph a couple of times. suprised me to only see mid 20's on mpg meter
Old 11-30-2006, 01:55 PM
bedwards's Avatar
bedwards bedwards is offline
bedwards is starting off with a positive reputation.
think I read somewhere that its like nearly a gallon an hour but I wouldn't let mine idle at all if I could help it
be
Old 11-30-2006, 02:07 PM
booker250's Avatar
booker250 booker250 is offline
booker250 is starting off with a positive reputation.
Quote:
Why do you let it run for 20 min in the morning?
Not necessary at all.
Old 11-30-2006, 02:14 PM
It's called "remote start" lazy....
Probably more like 8 - 10 minutes now, but when winter finally decides to come south, I like my truck toasty and defrosted when I get in....
Old 11-30-2006, 02:16 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
Former Vendor
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
Since you let the truck idle alot, be sure and run it HARD once it is up to full temperature to burn off any deposits in the EGR system and turbocharger made by the low idle temperature.
Old 11-30-2006, 02:24 PM
Great advice - thanks!
Old 11-30-2006, 02:25 PM
bneafus's Avatar
bneafus bneafus is offline
bneafus is starting off with a positive reputation.
I've got one of those Scan Gauges that has a GPH setting, never thought I'd need it. Now I'll have to look and report.
Old 11-30-2006, 06:03 PM
nico963's Avatar
nico963 nico963 is offline
nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.
I'm not sure about GPH, but I've heard that 1 hour of idling is equal to 33 miles driven,
I'm Not sure if their is any truth to this,It's just what I heard.
Old 11-30-2006, 06:05 PM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.
thats true, but it relates to oil service interval.
Old 11-30-2006, 09:28 PM
Former Vendor
Not sure about hard, strict numbers on the subject but I do know this- I was forced to leave my truck idling once for 9 hours (cold outside and had a faulty GPCM) and it didn't use a full quarter tank of fuel, so I'm not so certain about the 33 mile equivalent.
Old 11-30-2006, 09:57 PM
mrxlh's Avatar
mrxlh mrxlh is offline
mrxlh has a good reputation on FTE.mrxlh has a good reputation on FTE.mrxlh has a good reputation on FTE.
Matt was that at normal idle or the 1200 fast idle?
Old 11-30-2006, 10:50 PM
Former Vendor
Quote:
Normal. At the time I had not installed a high idle switch.
Old 11-30-2006, 11:20 PM
bneafus's Avatar
OK guys,when cold(coolant 55),idle at 800 rpm, it was saying 1.1 GPH.After I got to work and warmed up(170),and idling at 600 rpm, it says 0.8 GPH.
Old 11-30-2006, 11:34 PM
mlb4966's Avatar
mlb4966 mlb4966 is offline
mlb4966 is starting off with a positive reputation.
Quote:
Were did you get the Scan Gauge??? During the winter there are times when my truck will idle for hours. When its -60 and you are hours from the nearest town you dont shut off the truck.
Water in fuel sensor smoking. RangerAlpha12 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 01-05-2017 11:31 PM
1988 F150 running badly skidoorulz 1987 - 1996 F150 & Larger F-Series Trucks 14 06-24-2016 09:43 PM
Idle Issues Lonzo 1987 - 1996 F150 & Larger F-Series Trucks 0 01-08-2016 10:26 AM
Fuel Consumption at High Idle Jim McCarty 6.0L Power Stroke Diesel 3 06-13-2006 03:25 PM
Does a diesel burn less at idle? FredsF250TD 6.0L Power Stroke Diesel 36 07-14-2004 02:36 PM
Tags
46, 60, burn, burning, consumption, diesel, escape, ford, fuel, gas, gph, idle, idling, powerstroke, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
