No brake lights on my 86 F150 - Ford Truck Enthusiasts Forums
Old 11-30-2006, 11:32 AM
Dustin_86 Dustin_86 is offline
Dustin_86 is starting off with a positive reputation.
Question No brake lights on my 86 F150
I have all turn signals when the head lights are off tail lights work. NO brake lights, I replaced the brake light switch also. Is there a fuse?????
86 F150
Dustin
Old 12-01-2006, 02:22 PM
clunker86 clunker86 is offline
clunker86 is starting off with a positive reputation.
i believe there is a fuse for that but im not sure. does your e flashers work. i know when i was putting my 86 f250 together my brake lights would not come on when i pressed on the brakes. i replaced the switch an still no change. well from playing around, i found if you run a pos wire into one of the wires on the brake switch then it would work. im not sure what one out the two but on will cause the light to stay on and the other will only come on when you press the brake
Old 12-02-2006, 06:40 PM
dustin have you gave that tip a shot yet, did it fix the problem? hope she works soon for you
FordManMT's 95 F150xl 3/4ton SAS mud truck build FordManMT 1987 - 1996 F150 & Larger F-Series Trucks 5 08-26-2013 04:46 PM
frame strength? Dustin_86 1973 - 1979 F-100 & Larger F-Series Trucks 50 11-23-2006 10:16 AM
370 4V, a 330____ U-haul truck V8 Dustin_86 Performance & General Engine Building 1 02-20-2004 02:54 PM
1978 F-150 Towing? Dustin R Ford Inline Six, 200, 250, 4.9L / 300 6 10-09-2002 09:59 AM
1995 F-150 4X4 Gas MPG? Dustin44 1987 - 1996 F150 & Larger F-Series Trucks 28 12-12-2000 06:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
