Symptoms of a Bad Heater Core -OR- Head Gasket????
My truck (95 F150 6ycl 4.9L Auto) had been sitting for some time and I took it out for a 10 mile drive to get it some use. Shortly after starting I hear a large amount of fluid going through the heater core, then soon after the temp gage starts rising. Once the truck was to hot to drive, I pulled over and shut it down. I looked under the truck and a good amount of water was coming out at the transmission bell housing.
So is it likely that the heater core has dumped the fluid -OR- is this worse and the head gasket has blown -OR- where are the freeze plugs? Any guesses.......
Here are other items I noticed during and after this:
- While Hot lifters rattled heavily, but once cool and running no noise
- Checked the oil after the issues started and no obvious water in the oil
- Radiator drained afterwards, any attempt to refill would flush right out the back.
Definitely not the front hoses (to and from the radiator) and just checked the hoses to and from the heater core and those are both fine. I thought the truck had emptied itself of radiator fluid, but just before typing this I went outside and removed the radiator cap and heard water dripping (running really) out from underneath (truck not started). Laid under the truck and it's definitely coming from the back of the motor and actually through the transmission bell housing, as the transmission inspection port is removed and water is actually draining through the bell housing and out the inspection hole.
I am leaning towards the freeze plug as I had to have one replaced back in 2002. The truck has 210,000 miles on it so I am thinking this is why I am seeing these problems, that or when they worked on it in 2002 it wasn't done well.
I am praying it's not anything worse.
AMG-SM
29
09-09-2019 11:47 AM
holymolie
22
03-29-2011 12:54 AM
