56 for a 54 grill
56 ADs will work with 53-56 grill. 53-55 do not work with 56 grill. Could be dealers/parts houses stopped carrying the earlier ones for replacements once the 56 came out.
The difference is obvious once you see them both:
53-55 http://blueovaltruckparts.com/catalo...oducts_id=6664
56 http://blueovaltruckparts.com/catalo...ducts_id=14204
The parking light housings are also (but more subtle) different shape.
Originally Posted by Huntsman
My 55 had a 56 left ad and a 55 right ad, maybe replaced in a wreak at one time though no evidence of other damage showed up in sandblasting (paint layers were the same). Maybe they were just getting 56 units in and ran short on the 55's.
Received 1,344 Likes
on
Also, the '53 are slightly different than the '54 and '55. The '54 and '55 trucks have 2 rods that cross from side to side, they form an 'X' in front of the radiator. I think they are used to make the front end more stable and solid. They have 2 little arcs at the sides of the deflectors to allow the rods to pass by. The '53's did not have these. The '54-'55 will fit the '53 but not vice versa.
Received 4,119 Likes
on
Hi , I was just wondering because abe had mentioned that the 56 hood was different than the previous three years, the difference being the bolts at the cowl. I have three hoods all from 56 models and one from a 53 model which is the only one that has the stove head type bolts up close to the wind shield. I'm not trying to provoct an argument but was wondering if there may just be a difference between the USA models as compared to the Canadian models??
John
John
The 56 headlights sit in a little, a frenched look; not like the bug eyed 53-55 look.
This is why the air deflectors have a bump in them, for the clearance.
You can modify your old ones, and since they hardly are noticeable, they can be a good part to practice on. I saw one guy who just cut a circle about 6 inches and screwed on a modified small coffee can.
No, it wasn't me.
Paul
PS: I had to darn nearly give away my 54 grill, complete with new whiskers and parking lights about 5 years ago. Guess I should have thrown it on the junk parts pile with everything else!
I may have the lower valance for a 54 if necessary.
Paul
No, it wasn't me.
Paul
Paul
Also, you can modify the parking light housings with some careful trimming. I did that once to make (I believe) the 55s fit a 56.
I can't recall which ones are smaller/larger, but it's not much. I've seen small ones built up with a careful application of a U shaped rubber gasket around the edges.
Paul
Paul
plumkrazy
38
04-09-2020 07:07 AM
Steve Clarke
05-12-2011 09:26 PM
Chippen
09-30-2009 11:54 PM
fastbug
11-14-2007 09:08 PM
