blown intercooler hose
gb'sfx4,
It is a common problem in an over-boost situation. Sounds like the vanes may be sticking (common on the older designed turbo) or one of the senors is bad that controls the VV turbo.
You will probably need to take it in and have the tech test it to diagnose the problem and fix it. On a side note this question will get a larger response in the 6.0 section a couple of forums down.
Hope this helps
Hope this helps
I had my charge air hose clamp fail last week while towing. This was a week and 200 miles after the dealer had perfomed two TSB's one of which required removal of the turbo. I limped back to the dealer after dropping my trailer on the side of the road. Left after repair very unhappy as they insisted that I pay the $100 deductible even though they had just put all these parts back together. My thought was that since it was connected to the turbo it should have been covered under the emissions warranty not the powerstroke warranty... In addition since they had just worked on it I would have expected them to fix it and get me back on the road for nothing... Customer Relations??? Found a new service center that only sells and works on Ford Trucks...
The parts cost less than my deductible... 1 5C3Z-6C640AA hose and 2 6C62Z-6K786-AA clamps...
Dave
FORD HOSE TO TURBO (2004) #4C34-6C640-AA (NEW #6C3Z-6C640-C) NAPA #600-2972, DORMAN ALSO MAKE IT, BUT I DON'T HAVE THEIR PART NUMBER.
FORD DEALER $86.50
NAPA DEALER $40.00 (MADE IN CHINA)
YOU CAN ALSO USE A GOODYEAR RADIATOR HOSE AND CUT ONE END OFF #61128 $17.00 EACH.
THE 1ST HOSE LASTED 3 YEARS FROM FORD, THE 2ND RADIATOR HOSE LASTED 2 1/2 YEARS.
FORD NOW SUGGESTS YOU YOU HI-TEMP SILICONE ON THE HOSE AND LET IT DRY FOR 3 HOURS BEFORE YOU RUN THE TRUCK.
FORD DEALER $86.50
FORD DEALER $86.50
FORD DEALER $86.50
rsjimenez
6.4L Power Stroke Diesel
07-12-2015 06:43 PM
rsjimenez
1999 to 2016 Super Duty
06-22-2015 10:48 AM
Crazyotto1
11-13-2014 04:55 AM
