blown intercooler hose - Ford Truck Enthusiasts Forums
Old 11-29-2006, 10:33 PM
gb'sfx4's Avatar
gb'sfx4 gb'sfx4 is offline
old enough to know better
gb'sfx4 has a great reputation on FTE.gb'sfx4 has a great reputation on FTE.gb'sfx4 has a great reputation on FTE.gb'sfx4 has a great reputation on FTE.gb'sfx4 has a great reputation on FTE.
my 03 6.0 has blown the hose off the intercooler 4 times now.
it has about 110,000m. & blows off while towing & the turbo is spooling up.
common prob. ?
Old 11-30-2006, 05:51 AM
Bevis3's Avatar
Bevis3 Bevis3 is offline
Bevis3 is starting off with a positive reputation.
after doing some reading, it seems to be a problem. most say to clean the parts with brake cleaner, before putting it back together.
Old 11-30-2006, 10:53 AM
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
gb'sfx4,
It is a common problem in an over-boost situation. Sounds like the vanes may be sticking (common on the older designed turbo) or one of the senors is bad that controls the VV turbo.
You will probably need to take it in and have the tech test it to diagnose the problem and fix it. On a side note this question will get a larger response in the 6.0 section a couple of forums down.
Hope this helps
Old 11-30-2006, 11:01 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
are you talking about the small hose about 4in long?
if so Ford has updated the part number for a new type hose
part number 6C3Z6C640B List $49.65 FTE $35.78
this might fix the problem. I have one in stock.
Ed
Old 11-30-2006, 11:26 AM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.
you are probably over boosting like blackhat said. becareful, to much boost and bye bye headgaskets.
Old 11-30-2006, 01:22 PM
ANG&STEVES F350's Avatar
ANG&STEVES F350 ANG&STEVES F350 is offline
ANG&STEVES F350 is starting off with a positive reputation.
I had my charge air hose clamp fail last week while towing. This was a week and 200 miles after the dealer had perfomed two TSB's one of which required removal of the turbo. I limped back to the dealer after dropping my trailer on the side of the road. Left after repair very unhappy as they insisted that I pay the $100 deductible even though they had just put all these parts back together. My thought was that since it was connected to the turbo it should have been covered under the emissions warranty not the powerstroke warranty... In addition since they had just worked on it I would have expected them to fix it and get me back on the road for nothing... Customer Relations??? Found a new service center that only sells and works on Ford Trucks...
The parts cost less than my deductible... 1 5C3Z-6C640AA hose and 2 6C62Z-6K786-AA clamps...
Old 11-30-2006, 04:35 PM
gb'sfx4's Avatar
yeah, it came apart at the rubber coupling and was quite oily
I cleaned it up and added another hose clamp
it held even pulling a couple of steep grades
don't have a boost gauge, yet !
Old 12-06-2006, 05:58 PM
djousma djousma is offline
djousma has a great reputation on FTE.djousma has a great reputation on FTE.djousma has a great reputation on FTE.djousma has a great reputation on FTE.djousma has a great reputation on FTE.
I had one of those clamps fail on me too. It actually split. I was lucky, we were towing out TT home from camping last memorial day weekend, and my wife was driving separately. I sent her to autozone for a couple of 4" radiator type clamps, and put those on. I now have a couple spare ones that I keep with me when pulling the TT. That is one failure that will keep you stranded for something so simple and easy to fix.
Dave
Old 02-05-2010, 12:02 PM
JESCOSALES JESCOSALES is offline
JESCOSALES is starting off with a positive reputation.
FORD HOSE TO TURBO (2004) #4C34-6C640-AA (NEW #6C3Z-6C640-C) NAPA #600-2972, DORMAN ALSO MAKE IT, BUT I DON'T HAVE THEIR PART NUMBER.
FORD DEALER $86.50
NAPA DEALER $40.00 (MADE IN CHINA)
YOU CAN ALSO USE A GOODYEAR RADIATOR HOSE AND CUT ONE END OFF #61128 $17.00 EACH.
THE 1ST HOSE LASTED 3 YEARS FROM FORD, THE 2ND RADIATOR HOSE LASTED 2 1/2 YEARS.
FORD NOW SUGGESTS YOU YOU HI-TEMP SILICONE ON THE HOSE AND LET IT DRY FOR 3 HOURS BEFORE YOU RUN THE TRUCK.
Old 02-05-2010, 12:45 PM
Former Vendor
WHOA! OLD POST
Old 02-15-2011, 11:43 AM
4moretoyz 4moretoyz is offline
4moretoyz is starting off with a positive reputation.
Quote:
FORD DEALER $86.50
Great info, already saved me $, do you have the NAPA part # for the lower hot side 6.0 PS intercooler silicone hose? Thanks
Oil Leak from the Intercooler Boot on 2009 F350 6.4 rsjimenez 6.4L Power Stroke Diesel 7 07-12-2015 06:43 PM
Oil Leak from the bottom Intercooler Boot on 2009 F350 6.4 rsjimenez 1999 to 2016 Super Duty 0 06-22-2015 10:48 AM
Drivers side Intercooler boot keep popping off Crazyotto1 1999 - 2003 7.3L Power Stroke Diesel 11 11-13-2014 04:55 AM
Help! I'm Broken Down - No Boost 07 PSD rwhite2014 6.0L Power Stroke Diesel 26 08-12-2014 07:53 PM
6.0L Intercooler Repair? bigpowerstroke 1999 - 2003 7.3L Power Stroke Diesel 3 11-10-2010 03:14 PM
Tags
2004, 60, 6c3z6c640b, 6c640aa, blown, diesel, f350, failure, ford, hose, intercooler, overboost, part, repair, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
