1995 E-350 7.3L Diesel won't start - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-29-2006, 02:25 PM
ricknock ricknock is offline
ricknock is starting off with a positive reputation.
A couple weeks ago this vehicle started really rough - even using starting fluid - after being turned off for 30 minutes. I thought maybe my daughter had flooded it, so I drove it for 15 minutes then turned it off. The problem remained. After sitting 2 days it started normally.
This morning it won't start at all. I'm in SD, so assume the fuel has been winterized but am not positive. One time this afternoon it gave a couple pops like it was going to try to start, but nothing since.
Any ideas? Thanks in advance.
Old 11-29-2006, 03:11 PM
jeepcolorado1 jeepcolorado1 is offline
jeepcolorado1 is starting off with a positive reputation.
my first pass would be to check the glow plug relay, it looks like a Ford starter solenoid and on my 97 it's located directly on top of the engine next to the filter bowl. Make sure it has voltage at both large terminals when the key is in the on position. When you key the ignition, the relay should stay on for approximately 2 minutes. This is a very easy replacement.
If this isn't the problem, the glow plugs should be checked.
Old 11-29-2006, 03:26 PM
Thanks for the info jeepcolorado1. Sorry I forgot to say that I am trying to start this using starting fluid. In the past this has worked in even the coldest SD weather without even having to wait for the glow plugs.
On another forum (before I found this one) an owner of a 1999 was having a similar sounding problem. They told him it was almost certainly his cam sensor, but I couldn't find any info about my 1995, and am not mechanically inclined enough to know if this also applies to mine.
Old 11-29-2006, 03:40 PM
Update to starting problem
Vehicle just started by using starting fluid & not waiting for glow plugs. It was a bit rough, but idled ok after several minutes. Could problem possibly have been caused by cold fuel if it wasn't winterized? It was single digits here. At what temp does diesel gel? Will that prevent it from trying to start with starting fluid also? Or is it likely something else altogether? Thanks in advance for any and all suggestions. (I'll get some supplement & add just in case that's it.)
Old 11-29-2006, 04:21 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
I vote glow plugs. More than likely your fuel is winterized. If it was gelled it shouldn't have ran after starting on ether. Also if you get your glow plugs working don't use ether any more. It will make hole in thing that can't have hole in them! Ether explodes when exposed to glow plugs. if that were to happen on the up stroke of the engine it could have bad consequences.
Use a test light to check your glow plug relay. IF that is working then you need to test the glow plugs with a multimeter. The plugs should have continuity to ground with no more than about 3 ohms.
This is a van so this will not be very fun but its what it takes.
Good luck
Old 11-28-2012, 09:46 PM
SinistirX SinistirX is offline
SinistirX is starting off with a positive reputation.
i have the same problem with my 95 7.3 diesel everyone saying glow plugs starts when its warm out but if its cold wont start but if i plug it in a few hours before starting it it starts rite up
97 expediton,starting problem scrambledlife Expedition & Navigator 42 07-08-2016 11:03 PM
1975 f100 7.5L 460 start issue!! Dammnicetruck 1973 - 1979 F-100 & Larger F-Series Trucks 8 06-11-2015 11:41 PM
truck won't start cmusick 2004 - 2008 F150 0 01-27-2015 06:34 PM
96 Ford F150 dies while idling then won't start for a while Cheryl Rogers 1987 - 1996 F150 & Larger F-Series Trucks 57 02-19-2014 03:15 PM
'88 f350 5.8 won't turn over after driving george1016 1987 - 1996 F150 & Larger F-Series Trucks 11 10-30-2011 12:07 PM
Tags
1995, 2000, 73, 73l, diesel, e350, faq, ford, glow, location, plug, problem, relay, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
