Tips For Long HighWay Driving?
check your tires!
i live in GA but found my trophy truck in Kentucky, so i made my wife go with me and we made a weekend of it. when i got there the tires were so bald steel was showing. went to the local tire shop and the guy i bought the truck from split the price with me. not to bad since i felt like i was stealing it from him already!
also pump up the air in them to about 40, better fuel mileage and lesss likely the rubber will overheat
-cutts-
-cutts-
Originally Posted by fishmanndotcom
check your tires!
-cutts-
-cutts-
Franklin
well i didnt wanna suggest something too much. my max pressure is 45 but the more you can put in the better. just might be a lil harsher ride.
-cutts-
-cutts-
Franklin
on
1 Post
I am flying to Missouri to drive my new truck back to michigan tomorrow. This is a few things i am bringing with me. My spare cps and tools, bottle jack, windshield wipers, multimeter, fuel filter, Diesel Kleen winter blend, warm clothes incase I have to camp out. just a few things I am bringing. Good luck on your trip!
Thanks again!! I made it home no problems! I tried running with out diesel kleen and with... It seem to run much better when i was useing it. I'm so excited to start working on this truck to make it make it mine hehe First things first air and exhaust then a chip hopefully... just need to do the research!!
I start it up this morning (around 30 degrees out) and it sure did smoke but I read into and it was the white unburned fuel... I suppose letting the glow plugs warm up a lil more helps. I was wondering though is it better to let them keep going after the WTS light goes out or is it better to turn off and back on the ignition so the WTS comes on again?
Thanks again guys !!
I'm in Idaho. Overnight low's have been in the teen's and the high's in the low-30's. I plug mine in overnight to let the block heater do its thing. I have an F-350 and keep the tires at 60 psi, unless I'm hauling or pulling, (friends have horses and cattle, and horses and cattle need hay).
Haven't tried any Diesel Kleen, yet. Maybe I should give it a try. I'm getting around 16 mpg. Mine will do 75 mph @ 2100 rpm. Congratulations on your new ride. You're gonna love it.
