Replacing a power steering hose, need pointers - Ford Truck Enthusiasts Forums
Old 11-28-2006, 07:51 PM
97-F150-97 97-F150-97 is offline
97-F150-97 is starting off with a positive reputation.
Question Replacing a power steering hose, need pointers
O.k,
I need to replace a leaking powersteering hose. I have a '97 F150 with a 4.6 engine.
It appears to be leaking below the resovoir where the rubber tube turns into metal tubing. I am guessing this is the "pressure" line . I have a "Haynes" repair manual but it does not really give much info except for replacing the pump. With that job, it is saying to remove a ton of parts (shroud, skid plate,belt,brackets etc) to get access. Can I replace the hose without having to do all of that?
I just replaced the A/C clutch a few months back and had a hell of a time to get acess to the a/c compressor. I was trying to take of the shroud but found out I needed to remove the fan. Well, you need a special tool to hold the fan so you can remove it. I did not have that so I had to do the whole job from below. Anyway.... Anybody out that have any tricks,tips or idea what I'm in for?
Old 12-10-2006, 07:31 PM
searay220 searay220 is offline
searay220 is starting off with a positive reputation.
I know the high pressure hose can be a B***! The real problem is usually on the steering rack end of the hose connections. The low and high pressure hoses are over and under one another and so close together.
I have never replaced my truck high pressure hose, but on my Mustang it was easier to remove the pump and install the HP hose first then put the pump back in. On the rack end of the connections I had to bend a 11/16's end wrench at a 45* angle and also cut a 11/16's wrench off to create a very stubby open end wrench to get it done.
So what I am trying to convey is think outside the box and don't be afraid to be inventive. Good luck!
Old 12-11-2006, 03:12 AM
MazdaRangerGuyInSTL MazdaRangerGuyInSTL is offline
MazdaRangerGuyInSTL is starting off with a positive reputation.
Stubby wrenches are a godsend for these pressure lines... problem is they are very hard to turn by hand, and as a result you have to start the fitting with a wrench. Just make 100% certain it is starting straight before even starting to thread it in and DO NOT overtighten it.. the nylon seals don't resist crushing too well... even when tight you should be able to pivot the line inside the fitting.
Old 12-11-2006, 09:50 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
A crowfoot wrench on a long extension works well too.
Old 03-14-2008, 12:42 PM
britbiker britbiker is offline
britbiker is starting off with a positive reputation.
Hello guys,
I ' having the same problem on my 1998 F150.
The hose from the bottom of the resevoir is leaking where it goes from rubber to metal. I asked for a hose from Advanced Auto and they gave me 2 different hoses but neither looks like mine. I think I'll have to take it off and take it to them.
Did you get a replacement hose, if so from where and what is the part #.
I may try to take the front wheel off and go through the wheelwell.
Any help will be appreciated.
Thanks
92 Aerostar 4.0 ac hoses block radiator removal bleudia Aerostar 21 04-11-2014 02:30 PM
A/C problem Fixed on 5.4L in 20 Steps. runstang22 2004 - 2008 F150 2 08-08-2013 08:29 AM
GAHHH! I need a radiator and fan shroud! bicyclemonkey 1973 - 1979 F-100 & Larger F-Series Trucks 16 09-15-2009 10:58 PM
Replacing water pump 1989 460 CID tbear Cooling, Heating, Ventilation & A/C 2 12-14-2008 06:04 PM
Fan Clutch Diagnosis! larry derouin 1987 - 1996 F150 & Larger F-Series Trucks 3 04-05-2005 09:38 PM
Tags
150, 2003, 2008, 54, 97, changing, f150, ford, hose, installation, leaking, power, replacing, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
