Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #16 (permalink)
Old 01-30-2007, 08:32 AM
cje07's Avatar
cje07 is starting off with a positive reputation.
Quote:
Originally Posted by Kemicalburns
nice work, i am following your sag install on fsb as well. question. since you painted the rocker panels and rear quarters, how are you going to weld them into place? those pieces surely dont bolt in correct?
Just the top sides were painted...the bottoms were left unpainted. These are slip overs so what I will do is clean the existing rockers, POR15 them and then, 3M Glue them in place. Once installed the inside floor can be done with DURABAK to really seal the floor-rocker area. Quarter panels are the same...all of the glue points are NOT painted for adhesion. The 3M glue is much stronger than a spot weld and many of the body shops are switching tpo this stuff with fantastic results!
__________________
1986 Ford Bronco XLT[
302 EFI, manual 4 speed
K&N, 3G Alt, MK Classic II's
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Equus Mechanical Gagues
Edelbrock Shocks
Rancho lift
The Video: http://www.supermotors.net/vehicles...ry/media/619611
WARNING: Restoration in progress!!!
  #17 (permalink)
Old 01-30-2007, 08:36 AM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
very cool. i had no idea. i will be putting together my 85 this summer with everything from the rolled 88bko. i love this years bodystyle.
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #18 (permalink)
Old 01-30-2007, 08:38 AM
cje07's Avatar
Good luck! People will better be able to understand once I get to that point! I can not wait until this thing is finished!
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #19 (permalink)
Old 01-30-2007, 09:58 AM
cfrives3 is starting off with a positive reputation.
That is gonna be awesome. I too cannot wait to see it finished. Please continue posting pics, I'll be following closely!!!!!!!!!!
__________________
Charles F. Rives III
65 F-100 2wd-352 4v various mods, pretty quick
83 F-250-Obnoxious 6.9 Diesel on 38" Swampers
85 Bronco-still sittin stock, 300 I-6
86 Bronco-Eddie Bauer 351W 4v
-soon to be 408W stroker
  #20 (permalink)
Old 01-30-2007, 10:03 AM
cje07's Avatar
Quote:
As soon as the weather gets warmer (45-50) then I should be able to take a day off from work to put together the front clip (Hood, front fenders and doors). I will have to wait for much warmer weather to glue the rear quarters and do any floor work.
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #21 (permalink)
Old 03-29-2007, 02:38 PM
Any current pics? Did the Durabak coe in the tan color? How close would that tan be to the stock tan color on my 86 EB? I am assuming it is a spray on. Sorry for all the questions, But I am now very seriously doing the tan on mine with that stuff!
__________________
  #22 (permalink)
Old 03-29-2007, 03:10 PM
cje07's Avatar
cf3 - no current pics yet. I will need about a week or so to start the tear downa nd rebuild. Durabak come in the tan color. I think it is very close to the EB tan. You can either spray on or roll on. I actually rolled on the tan inside the rear fenders and bottom six inches to get a think coat on. These are the areas were the rocks, mud, small hondas and other debries kick up. The black smotth stuff I started to roll on but quickly switched to spray...much better pattern!
I also used POR15 on many of the surface rusted parts. Price varies by volume. Check out www.por15.com for more details. T
Here is the link:
https://www.durabakcompany.com/secure/order.htm
Tan Rough Coat (UV protection) = $119/gallon
Black Smooth (UV Protection) = $129/gallon
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #23 (permalink)
Old 03-29-2007, 03:49 PM
Wow! That stuff is expensive. Thanks for the other link-I'll probly join there too.
__________________
  #24 (permalink)
Old 03-30-2007, 12:07 PM
cje07's Avatar
Saginaw Pump
SAGINAW SWAP:
Hey everyone, I plan on posting a new how-to thread on FTE in regard to the Saginaw Swap. I finally got the highpressure retrun line a week ago and today finally got the stinkin bracket off the pump. My plan is to clean that baby up and paint it Ford Blue. Should lookpretty sweeeeeet when it is done. I'll post explaination in regard to install along with more pictures.
By the way, at some point I will take some long weekends to finish up the BIG project...I have to order some more Durabak Smooth Black and some more POR15.
Until next time!
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #25 (permalink)
Old 05-14-2007, 08:31 AM
cje07's Avatar
Hey fellas...and gals!
It's been a number of months since my last update. Just to inform you that I will be taking the end of May off from work to get a large chunk of work done. I just ordered another gallon of Durabak and invested in a quart of Rust Bullet. I do not not know what I am going to find underneath that carpet!
According to the Rust Bullet website the 1 qt size should cover 50 sq.ft (x2 coats)....should have plenty to cover the inside bed and inner wheel wells + any other part I think may need it. Stayed tuned for May 25th!!!:rockon
SAGINAW PUMP INSTALL:
I have the SAG stripped and had to JB Weld a tiny hole in the pump (very minor at the top of the pump). Now it is a matter of laying down some primer and painting. May use some RustBullet to coat instead of primer. Then the Ford Blue will go on. Man it is hard to get some shop time! I spent the whole weekend putting togther a swingset!
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #26 (permalink)
Old 05-14-2007, 05:13 PM
71dusterdan's Avatar
71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future71dusterdan has a brilliant future
Man was this ever inspiring, i believe you just gave me some solid ideas for my 89 250 4x. I just want it to be a solid work truck yet have been debating on body work. if i spray real auto topcoat it will look to nice to work, yet your route looks great and is proven to be resilient. Thanks, i have also been debating the glue on approach but was kinda concerned as to how it would work on the rockers and floors and cab corners but i believe you have convinced me to go for it. thanks, i will be anxiously awaiting your next installment. Dan
__________________
one sick puppy
Quote:
Originally Posted by 71Dusterdan
WOO WOO Shake wife at weiner
Quote:
Originally Posted by Adm Gary Roughhead, Chief Of Naval Operations
"I never want to see a Sailor or Marine in a fair fight. I always want them to have the advantage."
snl#16
Tims' minions - snatch and grab expert
  #27 (permalink)
Old 05-22-2007, 09:55 AM
cje07's Avatar
Its getting closer! Starting to get REALLY inspired after checking out several threads on resto's!
1) Recieved the extra gallon of smooth black Durabak
2) Received the quart of Rust Bullet
3) Got my self a high quality paint mask, gowns and more gloves too!
4) Swingset installed = kids happy
5) Backyard puppy proofed (new puppy last week)- wife happy
6) Tetherball pole installed in backyard - wife and kids happy
7) FRIDAY HERE I COME!!!!
If any of you have advice in regard to taking those front fenders off and installing new ones let me know. It's just a matter of screws and bolts...appropximate time to take one off? Alignment...anything I should know? Should I just re-align the new panels with the doors and work my way back?
By the way I had to show I picture of Jack:
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #28 (permalink)
Old 05-22-2007, 07:19 PM
Hey CJ-yellow lab or golden retriever? I have a female black lab, Chloe, and a male chocolate lab, Eli. Love the color of your toenails!! Ha Ha.
Know what you mean about making wife and kids happy-I've been working on the quads all day today, mine included. She wants to go riding memorial day, no matter what. I just want the motor issue solved on the EB. Have you read my threads on this? This is nuts. I have one in here and one in the small block forum. I also wrote one up over on FSB too. Check em out, see if you have any thoughts.
When you get some more done on your truck, throw up the pics. As for the fenders, how good of shape are your hinges/pins in? That would answer the question about whether to realign the doors. If they are not sagging, look square in the opening, (even gap all the way around), and close nicely I wouldn't mess with them. Your right, it's not a hard job, but it is definitely time consuming. Good luck. I wish you lived close I'd lend a hand doin it. See ya
__________________
  #29 (permalink)
Old 05-23-2007, 07:19 AM
cje07's Avatar
Funny guy! Jack is a yellow lab VERY well behaved and very intelligent!
Yeah I had been watching the thread but if I recall correctly it's a carbed engine correct? I don't know much about carbs and the systems behind them.
I replaced the hinge pins 3-4 years ago still in VERY good shape, so no problem with sagging doors. I will plan a full 8 hours for front clip...and hey...if I get more done then I will have exceeded my expectations. Buzz on over if you get bored at home...I could use the help!
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #30 (permalink)
Old 05-26-2007, 03:46 PM
cje07's Avatar
Progress made
First day off for the week-long project. I made, waht I think was pretty good progress. Was able to get the rock guard, both front fenders and the cowl put back on. On Tuesday, I'll progress to the hood and start taking out all of the interior! See below:
Front Fender Removal and Install
1) The first thing I did was to take the inner fender screws off. These were 7/32. You'll more then likely break a few, especially in the salt belt. There are also two larger belts under there (10mm) on the driver side and only one located on the passenger side. ( you may have to stick your head in the wheel well to see them.
2) There are also a number of 8 and 10mm bolts located at the following locations:
Front upper grill support
Lower grill support
Fender/Rock Guard connection
Make sure to rescue all of these clips
Larger bolts (1/2 inch) are located topside
[IMG]http://www.supermotors.net/getfile/437631/fullsize/fender-bolts.jpg
[/IMG]
There are two more large bolts; one is located behind the front well and before the door (underneath) and the other can only be seen by opening the door and looking through the crack. You will need a 10mm sockete and a long extension to get at it.
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
