2002 Ford F-150 transmission problems - Ford Truck Enthusiasts Forums
Old 11-28-2006, 01:45 PM
camsx2 camsx2 is offline
camsx2 is starting off with a positive reputation.
I have a 2002 Ford F-150 FX4 truck with 78,0000 mile on it. The other day the automatic transmission started to giving me problems. While driving down the highway the truck would shift into second then forth gear then back to third. Sometimes at a stop it would not go at all until the engine would rev high enough and it would clunk into gear. If I manual shift it to first, then it would go. I have changed the transmission fluid with Mercon V on regular intervals with little of no metal around the magnet in the pan or filter
I have read though several post in which other people who had the same problems and they seemed to think it was the shifter solenoid that had gone bad. Does anyone know how to replace this solenoid? Do I have to go into the transmission or is this an external part.
Any help would be greatly appreciated
Thanks,
Fred
Old 11-28-2006, 09:40 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi and welcome to the forum
To diagnose it properly I would have your dealer look at it. Transmissions can be pretty tough to diagnose without the right tools for the job such as a scan tool and pressure gauges etc.
If I had to guess I'd say that you have a bad TRS (Transmission Range Sensor). It's on the outside of the transmission where the shifter linkage attaches. It has 2 screws that hold it on and 1 electrical connector. It's easy to replace if you want to try that before getting it looked at.
Old 11-28-2006, 10:11 PM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
In addition, has there ever been a flashing OD lamp indication?
FYI there are a number of solenoids on the valve body. Which one?
See why better troubleshooting needs to be done?
Old 11-29-2006, 05:45 PM
I pulled the code from the OBD and i am getting a PO750. Any ideas?
Thanks,
Mark
Old 11-29-2006, 06:06 PM
Shift solenoid ..A.... error.
The code is the report for a winding short or open as detected by the PCM's electrical monitor.
Either fault means the shift won't take place in the proper sequence and becomes an error.
How the error is determined is by a number matrix that has software checks for all the correct shift sequences. If the shift results don't fit the matrix, the error is generated as well as the electrical failure from the monitor.
See why it jumped around?
F150 Transmission 5 speed OD 1995 fsaburro Clutch, Transmission, Differential, Axle & Transfer Case 13 11-07-2016 12:31 AM
Transmission help Donzi Dude 6.0L Power Stroke Diesel 9 11-11-2012 06:17 PM
'96 F-150 E4OD Issues IJRoorda Clutch, Transmission, Differential, Axle & Transfer Case 17 05-09-2012 09:42 AM
Need Help. Lot's of codes for TCC, O2 sensor heater circuits, evap solenoids terrysumner 1999 to 2016 Super Duty 3 01-19-2011 10:21 AM
Transmission shift problems 01HARLEY Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 2 01-05-2005 08:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
