Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Alberta Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Hallworth
  #1 (permalink)
Old 11-28-2006, 08:42 AM
RobInAB RobInAB is offline
Garage is empty, add now
RobInAB is starting off with a positive reputation.
-30...4 wheel or not
Hey guys, when the roads are like this in Edm....or alberta for that matter, are in in 4 hi constantly or do you switch back an forth or do you not use at all?
I love the traction I get but am concerned that the dry patches of road, as rare as they are, are hurting something while in 4wd.
Then my inclination is to switch back to 2wd. But then I get thinking that the transfer case is getting worked too much with the switching back and forth.
What do you do with 4wd in these conditions.
note..Im a new 4 wheeler
  #2 (permalink)
Old 11-28-2006, 03:37 PM
Digger6 Digger6 is offline
Digger6 is starting off with a positive reputation.
In town I run in 4 HI when roads are bad. I shift back to 2WD when I get on the highway. Most manufacures do not recomend using 4WD at speeds greater than 80km/h.
  #3 (permalink)
Old 11-28-2006, 04:11 PM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has a great reputation on FTE.seventyseven250 has a great reputation on FTE.seventyseven250 has a great reputation on FTE.seventyseven250 has a great reputation on FTE.
The only 4x4 trucks I ever drive are rentals, so I'm certainly not an expert. But I do know that if the driving lanes are snow covered, I'll throw it into 4x4. The way I see it, that way each tire is sending 1/2 of the tourque to the ground (vs 2wd) and is 1/2 as likely to slip.
Obvioulsy, I'm not terribly concerned about wear and tear on these trucks, as I'm driving them for a week at most.
Something to think about, if the road is bad enough to use 4wd, is it good enough to go faster than 80 kmh?
__________________
2005 F150 SuperCrew Lariat
  #4 (permalink)
Old 11-29-2006, 05:00 PM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
2003 Ford F-250
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
I use my 4x4 when needed. I shift in and out of it, in and out of town.
__________________
$Sheldon$
2003 F-250 supercab shortbox 4x4 lariat
~Everythings legal man as long as ya dont get caught~
A good fist fight never hurts anyone... except my opponent.
  #5 (permalink)
Old 11-29-2006, 09:12 PM
Dsl_Burner's Avatar
Dsl_Burner Dsl_Burner is offline
Dsl_Burner is starting off with a positive reputation.
I shift in and out of 4x4 around town. Just make sure your back and front tires are rototing at the same speed. No slamming into 4x4 while spinning out.
__________________
05 F-350 cc XLT sb 6spd build date 08/04
5" Pro-Comp lift/4" magnaflow duals staight piped
SCT X3 with Spartan tunes/ARP heads studs
Autometer boost,pyro and fuel gauge
CCV reroute/EGR disconnected/BD short throw shifter
Pioneer indash Dvd/navigation
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
