volare front end but what axle on a 55
Dave
An eight inch rim with a 255 wide tire fits almost perfectly in stock fender opening with the proper backspace. There is little room for error. If you stray far from the stock axle width, you have to account for it with custom backset rims. I am under the impression that the Chrysler axle normally associated with the Volare is too narrow, rather than too wide as your post stated. I would not be surprised if there was an early eighties Chrysler rearend with the proper width and bolt pattern. You will still have a rearend that falls miserably short of a Ford 9 inch though. They weren't quite good enough for a smogger 318. What are intending to put in the engine compartment?
Dewayne
53 F100
Dewayne
53 F100
