airbag light still on
There's really nothing more to reading the code than just watching the light and carefully counting pulses. It can be tricky, but you should get a two digit number, usually somewhere between 10 and 60 (from the ones I've seen mentioned on here). It's simple enough (starting the car) that you should be able to repeat it a few times to ensure that you've read the code right.
-Jim
-Jim
The way it works is it will walk through the system tests one by one from the lowest number to the highest. Here are the codes for a 2002 (from Ford docs). It looks like your almost there. As soon as it can get throught the system tests the light will go out and all will be fine and the system will be functional.
Here are the codes for Air Bag faults. When first started the dash light will blink the two digit code before it comes on permanently.
Continuous (blinks no code)
RCM Disconnected or Inoperative, Loss of Battery Feed, or Loss of
Signal Ground
15
Incorrect Vehicle ID
15
Driver Air Bag Circuit Shorted To
Ground
15
Battery Or Ignition
16
Passenger Air Bag Circuit Shorted
To Ground
16
To Battery Or Ignition
17
Air Bag Tone Warning Indicator
Circuit Shorted to Ground or Open
17
Driver Pretensioner Circuit
Shorted To Battery Or Ignition
17
Shorted To Ground
18
Passenger Pretensioner Circuit
18
Shorted To Ground
18
Circuit Short to Battery or
Ignition
19
RCM Crash Data Memory Full
21
RCM Bracket Ground Resistance
High
24
RCM Is Faulted
25
Passenger Air Bag Deactivation
(PAD) Switch Fault
27
(PAD) Warning Lamp Inoperative
27
(PAD) Warning Lamp Shorted to
Battery
32
Driver Air Bag Circuit Resistance
High
33
Resistance High
34
Low
35
Resistance Low
46
Resistance High
46
Resistance Low
47
Resistance High
47
Resistance Low
Dave
Signal Ground
15
15
Ground
15
Battery Or Ignition
16
To Ground
16
17
17
17
Shorted To Ground
18
18
Shorted To Ground
18
Ignition
19
21
High
24
RCM Is Faulted
25
(PAD) Switch Fault
27
27
Battery
32
High
33
Resistance High
34
Low
35
Resistance Low
46
Resistance High
46
Resistance Low
47
Resistance High
47
Resistance Low
Dave
