C4 transmission won't move when in gear
I just put a remanufactored transmission in my 55 (C4) and it doesn't move when I put it in gear. I put 7 quarts of fluid in it; I go through all the gears and nothing happens. Does it have to run a long time to build up pressure before it go into gear. I put 2qts. in the torque converter before installing.
Thanks in advance
Thanks in advance
I can't shoot you the fluid capacity of a C4 right off of the top of my head, but I'm almost positive that it is way more than a total of 7 quarts! That torque converter will hold a bunch. I'd almost bet that's where all of yours is at. I know this sounds stupid, but did you check the dipstick? I think you'll find out that you just need more red stuff. The fluid should circulate almost instantly when you start the engine. Well before you grab the shifter. There is no lag time, even with a new trans. The builder may have goofed somewhere, but I kinda doubt it. If that isn't it, also check to make sure you're using the correct bellhousing and torque converter if this is a new installation. There is a long and a short housing. If you've got the wrong one, you may be pulling the drive tabs out of the front pump when you bolt the converter to the flywheel. Result: No go!
daddy172005
09-05-2010 12:45 AM
1968F100ShortBed
07-20-2005 09:51 AM
racingdeathwish
12-21-2003 12:25 AM
racingdeathwish
12-19-2003 10:23 AM
