Power Seat Option for E350?
I was looking at a 2006 E350 as the family van, but my wife would like a power driver's seat, to get her up a little higher. Is there anywhere to buy an aftermarket power seat that fits these vans? even just a kit to raise the regular seat two inches would work.
The seat adjusts every way possible. The front rocker controls front tilt up and down, the rear rocker controls rear tilt up and down and the middle joy stick controlls forward to backward movement as well as entire seat up and down. The rear back rest also has a manual lever to adjust vertical back rest and there is also a manual lumbar dial on the opposite side of the seat to adjust lumbar support. excellent seat, the only thing it is missing is heat...
My wife has the same problem, likes to adjust it high and closer to the steering wheel. should be no problem for your wife.
The features you may find on a junk yard seat will vary depending on the year model that the seat came from. My '94 with factory electric seats has electricaly adjusted lumbar as well. The older seats also had two armrest instead of just one. I don't know what year the changes to the seat were made. Ford has a bad habbit of downgrading product lines the longer they continue to make them.
Gene
Gene
Recommendation for purchasing new (L) Econoline seat
The armrest broke off and I don’t want to try to weld it back on so I figured I’d just get another seat
The factory seats arm rests are often times completely replaceable.
The factory power seat tracks are north of 1000.00 anyway new
Just go get one out of a Taurus or Crown Vic at the wrecking yard and have someone mind meld it to your van
It will most likely bolt right in and you will have to wire it is all
Use a fuse link and a 30 amp maxi fuse for circuit protection
Good luck
Good luck
Alice's .:Project Yuki:. | 08-15 Ford E350 Extended Passenger Van (Preferably a Power Stroke Diesel)
AliceSML79
Projects
02-04-2017 01:47 AM
chuckster12
05-11-2016 03:04 PM
CraigH-CA
15
08-29-2011 06:00 PM
