Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-27-2006, 11:56 AM
Fredster Fredster is offline
Garage is empty, add now
Fredster is starting off with a positive reputation.
harmonic balancer removel on a 4.0?
How do you remove a harmonic balancer on a 91 Ranger 4.0 engine? It is not like balancers I have seen before. My Ford shop manual says to use
T74P-6316-A remover. I have a Snap on puller kit, but I cannot seem to make it work no matter what I do. Need help. Thanks.
  #2 (permalink)
Old 11-27-2006, 12:55 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
The threads in the balancer are metric. Nobody sells bolts (ok cap screws) long enough to use most standard pullers. Go get some threaded rod, cut it to however long it needs to be, and get four nuts, and some washers. Jam the nuts together on the one end, put the washers on, and assemble with your puller. You know what to do from there.
IIRC the right metric size is M7 or something like that.
  #3 (permalink)
Old 11-27-2006, 08:22 PM
The center bolt on my puller is to large to go through the hole in the damper. It has to go through the hole to reach the end of the crank.
  #4 (permalink)
Old 11-27-2006, 10:43 PM
ok...
You're doing it wrong. You put the crank bolt back in a couple threads, and turn the puller down on that. That should get it close enough that a few blows with a rubber mallet should take it off.
Doing it like you were trying could result in bunged up threads in the crank nose.
  #5 (permalink)
Old 12-01-2006, 07:22 PM
I found out all you have to do is use a 3/8" X 5" bolt and slide it in the
damper bolt hole so that it bottoms out in the crank bolt hole. Then use a regular balancer puller to push against the the 3/8" bolt. Real simple.
And no special tools.
Tags
40, balancer, balaner, ford, harmonic, liter, puller, ranger, removal, remove, sohc, t74p6316a, t74p6316b, t74p6316p, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
