94 F150 2WD Front Driver side Brake Line Leak - Ford Truck Enthusiasts Forums
Old 11-27-2006, 12:19 PM
robin22m robin22m is offline
robin22m is starting off with a positive reputation.
Pedal to the floor. Noticed brake fluid leak around Front Driver side wheel. Paid quite a bit to have rear undercarriage brake line sections replaced after similar problem (mulitiple leaks with that one). This occurrence seems to be dedicated to one area. Any thoughts/previous postings on replacing brake lines running towards front brakes? Is this something that can be accomplished through step by step instructions by an intermediate level person? Is there a lot of "fabrication" needed? Is the cable easy to manipulate? How difficult are access points? Should I pay in excess of $500 for this at a shop? 1994 2WD, V6 F150XL, w/ 143k miles. Thanks for the advice.
Old 11-27-2006, 01:49 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
$500 is way too much but of course i am saying that without the benefit of looking at the problem.
rusted brake lines are a bitch to get out. it is a dirty crappy job. to get the line back in is not as bad.
the brake connections are usually too rusted for wrenches, i just break them off and use vise grips.
Old 11-27-2006, 05:42 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
It can be done by someone with intermediate experience. Re-doing brake lines isn't that hard. If you can't find a kit, you can make your own brake lines with a cheap bending tool and a flaring kit. Then you can buy brake line by the roll and save yourself some money. Just make sure to duplicate all of the bends in the lines, especially the big coil under the master cylinder. It's important.
Old 11-27-2006, 09:47 PM
gumbydamit gumbydamit is offline
gumbydamit is starting off with a positive reputation.
Not too long ago I had to do my 96. Leak on Driver's side, the hose just came off at the crimp - go figure- (also after the rear, of course)...ended up doing both sides because getting it off damaged the metal tubing going to the passenger side. It can be frustrating. Requires some bending to match the tubing removed. I used a drill & hammer to get some of it out.
Because of the rust & stuff, it may take longer than you think. But I would NOT pay $500. I paid $150 for the rear but I was out of town or I would have done that myself.
Give it a go....
Good Luck,
Gumby
Question about a blown brake line and pedal to floor artfd 1997 - 2003 F150 10 05-16-2015 09:11 AM
Brake line question on a 99 trike1946 Expedition & Navigator 11 09-28-2014 10:51 AM
Brake problems rb2 1987 - 1996 F150 & Larger F-Series Trucks 1 07-30-2014 09:02 AM
'76 F-250, cannot bleed rear brakes szilagyic 1973 - 1979 F-100 & Larger F-Series Trucks 20 06-10-2010 09:24 AM
93 F150 Brake Diagram stangfan78 1987 - 1996 F150 & Larger F-Series Trucks 1 12-31-2008 02:34 PM
Tags
1996, 94, 97, brake, change, driver, f150, ford, front, leak, line, lines, metal, replacement, rust, side, step
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
