towing with a homemade bumper
Old 11-27-2006, 04:31 AM
2001gocougs's Avatar
2001gocougs
2001gocougs is offline
I have a 1/4 plate bumper made by the previous owner. It has a 2 inch receiver welded to the bumper and the step of the bumper.
I am wondering how I should have it tested (magnaflux)? Should I treat it at the same load rating as the stock bumper?
I am considering just purchasing a class 3 or 4 receiver hitch so I know the capabilities are legal and I won't have a run away trailer.
Any advice is appreciated.
Old 11-27-2006, 06:32 AM
jowilker's Avatar
jowilker
jowilker is offline
Farmers used those things for years, but mostly on the farm. The reciever hitches are very affordable and properly installed should be safer and give you the peace of mind as well. IMHO
John
Old 11-27-2006, 06:38 AM
Diesel Man 03's Avatar
Diesel Man 03
Diesel Man 03 is offline
I agree on buying a receiver hitch and installing it.Driving and not having to worry if your trailer is still behind you is a much better way to go.
Old 11-27-2006, 08:45 AM
Leader's Avatar
Leader
Leader is offline
Not sure I understand how you think buying a hitch made out of thinner steel will be stronger?
Hiow is it attached to your truck?
Old 11-27-2006, 09:44 AM
jowilker's Avatar
jowilker
jowilker is offline
Leader, It is called Engineering, and not the redneck kind either. IMHO
John
Old 11-27-2006, 11:09 AM
horsepuller's Avatar
horsepuller
horsepuller is offline
No matter how strong and heavy duty a bumper is, it's weakest point is the flanges it's mounted to. Those flanges are not designed strong enough for the torsional loads a trailer puts on the bumper.
Old 11-27-2006, 11:40 AM
Leader's Avatar
Leader
Leader is offline
So... the 1/4" plate steel brackets welded from the truck frame to the bumper aren't strong enough to pull a trailer???
Ok.. Glad you let me know that.
I'll just pay for that 1/8" bracket on that $200 hitch bolted on so I'll be "safe".
Old 11-27-2006, 12:09 PM
Eric C.'s Avatar
Eric C.
Eric C. is offline
Thumbs down
It's a liability thing and if you're comfortable with trusting a job done by Who Know's, from I Don''t Know When, that was Tested By Only God Know's, then Have Fun and Where Do You Live so I can stay away???
Old 11-27-2006, 08:27 PM
jorlee's Avatar
jorlee
jorlee is offline
Could you get some pics of it for the people who don't understand how thick 1/4inch steel is? Make sure to get some from underneath to see how it is mounted.
I have seen many custom built front and rear bumpers. I'd trust them farther than any receiver hitch today. Receivers are cheap and easy that's why their everywhere. If I had the money I'd rather have custom bumpers put on my F-150 cuz I darn well they won't fold over like tinfoil when I encounter a deer on the road or a short stopping honda.
P.S. Don't bash what you haven't tried nor saw.
Old 11-29-2006, 06:55 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
If the bumper is made of 1/4 steel and bolted directly to the frame, just add bolts for piece of mind.
If the receiver is an aftermarket type, there should be holes in it already for it to be bolted to a step bumper. Just drill the holes in the 1/4 plate that matches to the holes and add the bolts. There should be holes for (2) 5/8" grade 8 bolts and (2) 9/16" grade 8 bolts. You only need one set of either, I usually use both. Bolts are cheap.
Personally I would buy a hitch. Good insurance for $120-$150. Most 6K or better are made from 1/4-5/16" plate steel and tubing all around. I have NEVER seen a 5k-6k hitch made from 1/8" steel, NEVER, and I have seen a lot!
On the factory hitches the welds can be trusted and the side plates spread the load across the frame and flanges instead of putting it all at the end of the frame. Which makes the truck handle better.
Old 12-09-2006, 08:32 PM
ckal704's Avatar
ckal704
ckal704 is offline
I, too, am in the "buy a hitch" camp.
Were your bumper hitch to fail, you would be likely be liable for all damages.
Receiver hitches are designed by mechanical engineers and use materials of known quality and welding processes that have been proven to withstand the loads at which the hitch is rated.
How can you tell how well these welds were executed? Was the man certified? What electrodes did he use? Are the welds subject to brittleness?
I think the bumper hitch is good for around the farm or up at the camp, but I would hesitate to hitch anything heavy to it for a long haul over the road.
Call me chicken.
Old 12-10-2006, 07:19 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is online now
Another vote for buying the reciever hitch and for all the aformentioned reasons summed up in two words. Safety and liability.
Safety for your fellow travelers on the road.
And liability if your trailer decides to go it's own way and kills someone. You could lose everything you own and be in debt for life. Wanna risk that over a $200.00 reciever hitch?
Old 12-10-2006, 11:08 AM
firesoutmatt's Avatar
firesoutmatt
firesoutmatt is offline
Just remember if that trailer comes loose (hitch fault or not) and they look at it for the cause of an accident you will be who hoo not a happy camper.
Old 12-10-2006, 10:15 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Another thing; 1/4" cold rolled steel is not in the same league as the alloy steel used in...hitch...designs.
1/4' don't mean a thing!
Sully007
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
01-02-2021 03:32 PM
polarspeed
13
04-29-2016 02:59 PM
Leef250
06-26-2015 10:56 AM
1975FordF250
02-10-2014 06:56 PM
95bogginbronco
1978 - 1996 Big Bronco
07-12-2007 11:44 PM
Quick Reply: towing with a homemade bumper
