pyrometer
The clamp style uses a large "radiator" clamp that raps around the exhaust piping to hold the sensor in place. People often complain of exhaust leakage with these. When putting them in the pipe, this is a common method because the pipe isn't really thick enough to tape and then securely screw the sensor in.
The drill and tap requires you to drill, tap the hole, and the screw the sensor in place. Less leakage, more permanent installation, but it takes longer.
I was originally going to just clamp my sensor on for time reasons, but now I will probably just drill and tap the exhaust manifold.
on
I have heard many say they just drilled it tapped if and then used a vacum to suck it clean. Others have used grease on the drill and tap to stick the shavings there. Can't say from experience cause I've never done on. Just go slow. And when you tap don't run the tap all the way in, Just like half way or 3/4 of the way.
Right on with the vacum. I drilled it, then used a shopvac on it. Then I tapped it *slowly!* and sucked it out with the shopvac again. I cleaned the tap several times and it worked out really well. I also used some grease on it. The only hard part was keeping metal shavings out of your face!
2New2Fords
13
09-21-2006 08:38 PM
