Fuel Filter Installation. Help!
Desperately need help installing the cartridge type fuel filter in a 1986 Bronco II with 2.9L.
I've now gone thru 3 O-rings (and by default 3 filters)trying to figure out where the damn O-ring goes to keep it from leaking.
There is a liitle groove in the bottom of the cup that looks like it should hold the o-ring. Unfortunately the O-ring appers to be a little to big for that. I've tried it but it leaks like a sive when you start her up.
I've tried the top of the threads on the male side of the filter housing on the truck but there doesn't seem to be a groove for just the o-ring so I can't get it seated right. Leaks like a sive as well.
What am I missing?
Any help greatly appreciated
What am I missing?
Sorry I honestly can't remember. I do remember cleaning silicone out of a groove for an o-ring. That's where I got the idea of putting silicone on it when I put it back together. I don't think the groove was at the very bottom of the cup. It may have been right below the threads on the cup or maybe even on where the cup screws into. The previus owner never put the O-ring in it. They just used silicone to seal it. Never leaked.
Been six+ years or so since I did one, but, I thought the o-ring went on the cup on the outside under the threads! The filter just went directly into the cup by itself. You do have to tighten these down very hard and the easiest way is to do it off the vehicle holding it in a vise while using a belt or oil filter strap to tighten the cup.
Please note, if you do not have the filter pressed down and centered you can never tighten it enough to seal it.
Which is why it is best done off the vehicle.
Do not use plyers on the filter housing, you will crack it.
franknorman
17
09-08-2016 11:13 PM
hotroddsl
17
09-15-2015 11:29 AM
mechelement
08-11-2015 06:46 AM
CarpAdm
12-28-2014 10:40 AM
