Brake Rotor Minimum Thickness - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-26-2006, 12:13 AM
teg2_nv teg2_nv is offline
teg2_nv is starting off with a positive reputation.
Does any one know the minumum front brake rotor thickness for a 2000 F-350 4x4 Dually. The spec is rusted and I can't tell if it is 30.0 mm, 36.0mm or 38.0mm.
Old 11-26-2006, 12:55 AM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
2002 specs
https://www.fleet.ford.com/truckBBAS...2/fsersdcd.pdf
area/width/thickness
12.40/1.89/.47
Replace Rotors too? acamk37 1999 to 2016 Super Duty 13 02-19-2015 12:05 PM
Disc conversion--IMPORTANT INFO!! F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 19 10-23-2010 05:37 PM
BRAKE PAD MINIMUM THICKNESS A H DEVELOPMENT 1999 to 2016 Super Duty 3 01-25-2010 06:17 PM
brake rotor size? 86fu50 1999 - 2003 7.3L Power Stroke Diesel 0 06-11-2008 06:44 PM
Minimum rotor thickness F250 ??? jetta4 Brakes, Steering, Suspension, Tires, & Wheels 1 02-06-2005 06:58 PM
Tags
150, 2002, brake, duty, f150, f250, f350, ford, measure, min, minimum, rotor, super, thickness, truck, wear, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
