11-25-2006, 01:32 PM
Because of the frequent short trips the truck operates in warm-up mode for much of the time, not really getting up to proper operating temp for very long. This would be why you tend to see a lot of carbon build-up. I would add a good fuel system/injector cleaner such as Seafoam on a fairly regular basis, and manually clean the throttle body, IAC and Mass Air sensor, perhaps as often as every few months. If EGR-equipped, you should clean that every once in a while as well. You may need more frequent tune-ups and oil changes than specified, as your driving habits come under the heading of Severe Duty.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
