Max Rpm On 360 fe
Originally Posted by Bear 45/70
Engine rpm is dependent on rear axle ratio ratio and tire size. Without those numbers no one can tell you anthing about your setup, only what their setup does.
Mine had a 3.25 in it too and with 235/85-16's it for sure wasn't gettin over reved! (360 with T18 here)
I like my new ratio!
Went to 3.50 when the pilot bearing surface on the pinion went bad.
My odometer is still off but the speedometer just happens to be right on the money now. I adjusted the speedometer years ago and never was quite enough but was all I felt like I should... it would just barily return to zero.
The odometer could be corrected now with a nylon gear change, but ain't gonna do it.
Alvin in AZ (30-30 bear, mt.lion, jackrabbits, lizards, mud puddles and whatever else was around
Unless it is acutually an overdrive tranny, final output is 1:1; same as any other tranny.
http://victorylibrary.com/mopar/car-tire.htm
If the link works, there is a pretty nice chart that gives you an idea of installed height for different section width and aspect ratio tires. The math is already done, the chart stays put, it is very easy to use.
It's expensive, but it would work.
It might be money well spent to get a tach and find out just how fast the engine is turning. Might be that your auto tranny is sliping, contributing to a higher RPM. Trying to push a truck through an O/D might get you into a tranny rebuild even sooner.
I took the info you already gave, used the tire chart and a gear calculator to see what RPMs you should be turning at "free way" speeds. Here's the calculator: https://www.ford-trucks.com/calculat...mph_rpm/a-rpm/
3.25 R&P, 26" nominal tires:
55 mph/2310 RPM
65 mph/2730 RPM
75 mph/3150 RPM
Yeah, you could drop some RPMs and be ok. For the price of an O/D unit, you could rebuild the tranny and put new tires-or whatever on the truck.
Just some more food for thought, Mike
Originally Posted by keisha9
....i think its revving pretty high on free way and dont know what cruising speed rpm is good .
55 mph/2310 RPM
65 mph/2730 RPM
75 mph/3150 RPM
460jared96
06-01-2015 06:55 AM
GamerGirlAlice
01-17-2013 11:15 PM
Victor L
10-05-2010 07:44 PM
highboyf25073
08-26-2004 09:40 PM
