Three questions: FFV, and Fx4 v. Lariat
#32
The FFV engines are basically the same with upgraded fuel sytem/lines to handle the corrosive effects of E85. The computer also compensates for the octane of the fuel as far as timing is concerned. The engine should be just fine. As far as seats there should not be much difference. Can't say if the shocks are true rancho's or not but they are a tad stiffer than the XLT's. Drove both the XLT and FX4 and you could notice the difference. Not sure about the Lariat or KR. I don't really think one is an upgrade over the other as far as components. More of a trim difference between the Fx4 and Lariat. Feel good about either one. I would go with the one you think looks best and fits your needs as far as trim levels. Everything underneath is all the same.
#33
If you want to know which parts of your seats are leather and which are vinyl, just push on the seat with you finger. The leather parts will wrinkle around the tip of your finger and the vinyl parts wont. Ford says the seats in the Lariat and FX4 have "leather seating surfaces". Pretty much the whole part of the front captains chairs you sit on are leather, the sides, backs and headrests are vinyl. On the back seat only the two panels where the ouside passengers sit are leather, the rest is vinyl. Only the King Ranch seats are all leather. Don't beleive it? Try the finger test. If you don't beleive that ask a reputable upholstery shop or pull the covers off yourself. I can honestly say that there is very little leather on my Lariat's back seat.
#35
#36
#37
#39
wow, another old thread revival
the shocks may/may not be Rancho on a FX4...but they are different part #'s between the reg 4x4 and FX4
as for the seats...the entire seat looks identical to me. I cannot tell a difference if they are 1/2 leather and 1/2 vinyl.
if you just want a 4x4 truck to cruise around in, get a Lariat. If you want a truck that is nicely optioned and good offroad, then look at a FX4.
the FX4 comes standard with:
5.4 3v
3.73 gears
Limited Slip
Tow Package (Transmission Cooler & 4/7 pin connections)
Skid Plates
Wider Wheels (slightly)
Sticker
vs. a Lariat which can get all of the above options, but at slightly more $$$. It's always cheaper to buy as a package than to peicemeal togother. oh yeah, and you can get every option the Lariat offers except the Trip Computer
3.73 gears
Limited Slip
Skid Plates
Sticker
#40
