NEED Fuse panel diagram - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 11-23-2006, 02:33 PM
eaten2 eaten2 is offline
eaten2 is starting off with a positive reputation.
91 ford aerostar...turn signals dont work.....need fuse panel diagram..not sure if it is the blinker fuse or the main fuse
Old 11-24-2006, 12:54 AM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
Replace both the fuses and check the relay. But first check the emergency light switch under the steering column. If it is not pushed up well, turn signals dont work.
Old 11-24-2006, 03:07 AM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
Fuse Panel Aerostar
click for fuse panel pic
AEROSTAR FUSE PANEL Fuse Position Amps Circuits Protected
1 15 Amp Fuse Hazard Flasher, Stoplamps, Indicator Lamps, Speed Control, Brake Shift Interlock
2 6.0 Amp C.B. Windshield Wiper/Washer
3 Not Used
4 15 Amp Fuse Side Marker Lamps, Headlamp On Warning Chime, Under hood Lamp, Daytime Running Lamps (DRL), Parking Lamps, License Lamps, Instrument Panel Illumination, RABS "Keep Alive"
5 15 Amp Fuse Turn Signal Flasher, Air Bag Module, Backup Lamps, DRL Module, Rear Defroster Switch, Turn Signal Indicator, Brake Shift Interlock
6 20 Amp Fuse Speed Control Amplifier, Warning Chime Module, A/C Clutch, Door Ajar Relay
7 20 Amp Fuse Rear Anti-Lock Brake System (RABS) Module
8 15 Amp Fuse Illuminated Entry, Stepwell Lamp, Cargo Lamp, Power Mirrors, Courtesy Lamp, PSOM, Clock, Glove Box Lamp, Visor Vanity Lamps, I/P Courtesy Lamps, Dome Lamp, Reading Lamps
9 30 Amp Fuse Aux. A/C, Front A/C Blower Motor
10 15 Amp Fuse Air Bag Module
11 15 Amp Fuse Radio, Amplifier
12 30 Amp Fuse Power Lumbar, Flash to Pass, High Beam Indicator, Horns
13 5 Amp Fuse Instrument and Control Illumination
14 20 Amp C.B. Power Window Motors
15 15 Amp Fuse A.W.D. Module and Indicator
16 20 Amp Fuse Front Cigar Lighter, Rear Cigar Lighter
17 10 Amp Fuse PSOM
18 15 Amp Fuse Warning Chime, Instrument Cluster, Rear Wiper Motor, Rear Washer Pump
Fuse Block Bracket 4.5 Amp C.B. Rear Wiper Motor, Rear Washer Pump
Under dash fuse box diagram Rick Henry Ranger & B-Series 2 03-09-2016 06:00 PM
Fuse Panel Diagram 1999 Ranger tws14 Ranger & B-Series 3 01-20-2008 03:31 PM
1999 Ranger Fuse Panel Diagram tws14 Ranger & B-Series 1 01-19-2008 03:21 PM
Need fuse panel diagram for 78 F150 cascios 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-03-2006 12:37 PM
1970 Fuse panel diagram? cabronco 1966 - 1977 Early Broncos 2 07-08-2004 08:43 AM
Tags
96, aerostar, blinkers, box, control, diagram, drl, dutybrake, e450, f150, flasher, ford, fuse, fuses, hood, interlockspeed, module, panel, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
