TTB to SAS, help needed.
I was reading the thread about lifting a TTB now I am wondering about a SAS too. What are the parts needed and years of the parts
Solid Dana 44
Coil or leaf
Tie rods
what else
Would you consider this less expensive?
Also I would like to lift My Bronco to fit 35s. I can add leaves to the rear.
I like the handling of a Solid axle over the TTB anyday.
Any help from you guys would be great.
Aloha d.
Solid Dana 44
Coil or leaf
Tie rods
what else
Aloha d.
I did an sas on my 94 supercab 150. It's time consuming but not that hard. I went with around 11-12 inch lift. As far as money goes, I had alot tied up in new steering components- tie rod ends drag link etc. I used a coil front end from a 78-79 and the stock radius arms for it. There are pics in my gallery.
