stub shaft removal dana 50 Twin Beam ??? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-23-2006, 11:51 AM
BKB BKB is offline
BKB is starting off with a positive reputation.
I got a 97 f250 HD with the Dana 50 twin beam front end. Im replacing the knuckle u-joints and i cant remove the passenger side axle from the carrier. The drivers side slid out with little effort i dont see why they would use a c-clip on one side. I had a pry bar on it and no movement at all. I guess my next option is to cut the bands on the slider boot and slip out half of the axle. Am i missing something???
Old 11-23-2006, 01:45 PM
Lou Braun Lou Braun is offline
Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.
As you guessed, the c-band and boot between the passenger's side stub shaft and the inner u-joint needs to be disassembled. The stub shaft will then slip off.
The inner axle is held into the front differential with a c-clip. You would need to remove the differential's cover and remove the c-clip to pull the inner axle.
Lou Braun
Solid axle swap rampus 1987 - 1996 F150 & Larger F-Series Trucks 2 03-14-2011 02:01 AM
lowering twin i beam hunter62 1961 - 1966 F-100 & Larger F-Series Trucks 2 11-25-2009 11:29 PM
twin I beam to dana 50 swap bill11012 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 49 09-19-2009 09:41 PM
Twin I-Beam Camber llehmn 1968-2013 Full Size Vans 9 10-06-2005 08:54 PM
Twin I-beam to strait axle swap. knwrth2 1999 to 2016 Super Duty 3 06-19-2002 07:39 AM
Tags
1994, 50, axle, beam, dana, ford, fords, front, ibeam, middle, removal, removeale, removing, shaft, slip, stub, twin, ujoint, ujoints
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
