You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
im building a 545 to run on propane and was wondering how hard it is to tune the dual quad setup id need to get enough flow for the engine. any tips besides the old exhaust gas analyzer and playing with settings?
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
__________________
'77F1504x4, '75 f250crew4x4, '79 Bronco 429, '83 bronco, '72 Torino with 351cj, 70 1/2 falcon, 75 stangII. all projects, 2 on the road. One pissed off wife!
Air-valve propane carburetors like the Impco 425 supply fuel based on air flow and not load. The only external fuel mixture adjustments on this type of mixer are full-throttle power and idle mixture. Ideally, you put a CO analyser in the tailpipe and adjust the power mixture screw so that the full throttle CO reading is 1.5% to 2.0%.
It is always safer with propane or natural gas to go lean rather than rich. Rich mixtures burn exhaust valves because gaseous fuels do not have the evaporative cooling effects of liquid fuels. Since the air valve only senses air flow, you will likely find that your fuel economy will improve if you adjust the power valve to be on the lean side. The only danger from lean fuel mixtures is a lean misfire. Lean fuel mixtures (as with gasoline) burn a bit slower which means you will need a bit more spark advance. Once you've found a lean fuel mixture that still runs satisfactorily, try adjusting the spark advance to improve your fuel economy.
The best guide to setting up either the Impco 425 or the OHG X-450 mixer is Franz Hofmann's Diagnostic Guide. It is available on his web site for a very reasonable price.
Obviously, for a dual quad setup, you need to make identical adjustments to each carburetor.
thank you i picked up his guide about a month ago and read through alot of it, but havent been able to put it into practice as yet. im looking at buying a house right now so vehicle projects have kind of been put on the backburner, but i appreciate the input
__________________
drive trane parts may strand you, but suspension parts can kill you.
if you cant pay cash for it, you cant afford it.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
