Heated Mirrors on a F150
11-22-2006, 09:55 PM
on
Does anyone know if you can easily install heated, power mirrors on a 2003 truck that came from the factory with just power mirrors? Does it need a switch or does it work off of a thermostat? Thanks in advance & great site! Ed
11-23-2006, 09:43 AM
The wiring should be in the door if not in the plug, and if they are anything like the SD mirrors they are always on when the truck is.
10-17-2011, 08:56 PM
on
THe wiring is not in the door. Heated mirrors were not offered on 97-03 F-150's. 04 was first year. It's not as easy to do as you'd think. If you go the post asking about Expedition mirrors on a F-150, I laid out the best or correct way to do it there. You basically have to take 4 mirrors to make 2. I am doing it on my 03 F-150 reg cab right now. I used the expedition mirrors with heat and signals. My truck will look like a factory installation when it's done. Right now I am working on getting a timer module so the mirrors don't stat on all the time. Read it and you'll see how to do it.
Barry
Ford parts man
01-31-2013, 10:46 PM
on
Can you post pics or give a parts list? I'd love to do this, and what harnesses or plugs to buy? If nothing else, a pic of the replaced dash panel with the switch.
Thanks!
11-06-2013, 10:09 AM
on
hey bmccl in the process of changing bases of expy mirrors to a 97 f150. Found if you pull the wires out of the swivel part then take a hose clamp put it around the tabs tight then take a heavy putty knife/scraper and pry up you can get the base off if your carefull.
twstevens96
2015 - 2020 F150
07-24-2018 04:17 PM
jprix
1997-2006 Expedition & Navigator
23
09-18-2017 09:02 AM
Waff78
2004 - 2008 F150
02-06-2015 09:55 AM
i eat hybrids
04-22-2012 08:02 PM
Firefighter 1406
1999 to 2016 Super Duty
17
10-31-2011 07:28 PM
03,
1997,
19972003,
2003,
2006,
96,
davidson,
f150,
ford,
harley,
heated,
install,
installing,
mirrors,
truck
