Heated Mirrors on a F150 - Ford Truck Enthusiasts Forums
Old 11-22-2006, 09:55 PM
fatseddie fatseddie is offline
fatseddie is starting off with a positive reputation.
Does anyone know if you can easily install heated, power mirrors on a 2003 truck that came from the factory with just power mirrors? Does it need a switch or does it work off of a thermostat? Thanks in advance & great site! Ed
Old 11-23-2006, 09:43 AM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
The wiring should be in the door if not in the plug, and if they are anything like the SD mirrors they are always on when the truck is.
Old 10-17-2011, 08:56 PM
bmccl's Avatar
bmccl bmccl is offline
bmccl is starting off with a positive reputation.
THe wiring is not in the door. Heated mirrors were not offered on 97-03 F-150's. 04 was first year. It's not as easy to do as you'd think. If you go the post asking about Expedition mirrors on a F-150, I laid out the best or correct way to do it there. You basically have to take 4 mirrors to make 2. I am doing it on my 03 F-150 reg cab right now. I used the expedition mirrors with heat and signals. My truck will look like a factory installation when it's done. Right now I am working on getting a timer module so the mirrors don't stat on all the time. Read it and you'll see how to do it.
Barry
Ford parts man
Old 01-31-2013, 10:46 PM
jblueguy jblueguy is offline
jblueguy is starting off with a positive reputation.
Can you post pics or give a parts list? I'd love to do this, and what harnesses or plugs to buy? If nothing else, a pic of the replaced dash panel with the switch.
Thanks!
Old 11-06-2013, 10:09 AM
fordfan1997 fordfan1997 is offline
fordfan1997 is starting off with a positive reputation.
hey bmccl in the process of changing bases of expy mirrors to a 97 f150. Found if you pull the wires out of the swivel part then take a hose clamp put it around the tabs tight then take a heavy putty knife/scraper and pry up you can get the base off if your carefull.
2015 F150 Adding heated/tow mirrors twstevens96 2015+ F150 0 03-15-2016 12:08 PM
2000+ power mirror connector pin out? jprix 1997-2006 Expedition & Navigator 21 02-02-2016 10:27 AM
'07 side mirror upgrade Waff78 2004 - 2008 F150 3 02-06-2015 09:55 AM
2010 tow mirrors on a 06. Need help asap. i eat hybrids 6.0L Power Stroke Diesel 8 04-22-2012 08:02 PM
Mirror Heat Amp Draw Firefighter 1406 1999 to 2016 Super Duty 17 10-31-2011 07:28 PM
Tags
03, 1997, 19972003, 2003, 2006, 96, davidson, f150, ford, harley, heated, install, installing, mirrors, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
