pulsating engine
pulsating engine
heres the deal. becuase the truck was having a hard time starting when cold, i replaced the distributor cap and rotor (which both had some corosion), as well as checked the plugs and IAC. So far this week, no more hard starts, but now the engine pulsates while running hot. during idle a pattern of pulsates can be recognized. when driving under highway speeds, another pattern of pulses can be detected but it is sparatic. often the pulsating shakes the steering column, and a passanger even could feel the shaking.
i have checked to make sure that the wires to the plugs are in the right order. the first time i noticed this was after i removed a plug to check it, and replaced it, and befor i replaced the distributor cap.
thanks
thanks
well i bought new wires, and just had time to install the one that i thought might be broke. well its still doing it. and to make a correction its not so much of a shivering type vibration, which periodicaly is bad enough to shake the truck and stearing column. as soon as i get home, im going to change out the rest of the wires and check that one plug again. so well just have to see
yeah, 1.50$ is the best kind of fix! the only question that i have now, is that the idle speed is higher now, both out of gear and in gear, then before. could i have bumped something in the engine compartment, or would this just be a result of the new plug wires i installed along with the new plug? should i lower it back down to around 700, its at about 10-1100 right now
mikulskn
1997-2006 Expedition & Navigator
06-26-2013 11:23 PM
